Memory circuit organizations for a 4GB 64-bit module
  • Thread starter Thread starter wingman-001
    Memory
7 replies · 2K views · last reply
wingman-001
This task is related to RAM memory organization. Question is:
"Which memory circuit organization is required on 4GB memory module if every circuit participate equally in 64-bit of memory module? Write at least two organizations."
I don't know what should I use here but there are some formulas to use for sure.
I don't know how to start but solution should be something like 256x8 or something in that fashion.
I need steps with equations and explanation which lead to solution.
Thank you very much!
Okay, there is one similar example which is solved.
Which organization is required in order to get memory size of 2GB by using 16 memory chips? And solution is:
D=2GB
Nic=16
Nb | ic =?
Nb | ic = 64/16 = 4
Nd | ic = D / Nic = 2048MB / 16 = 128MB
Solution--> ORG=256Mbx4.
So, this example is very similar to my problem, but I don't know how to calculate.
I already have that and I can't understand what I need to do. Anyway, I think this problem should resolve someone who knows computer architecture very good. I don't have a picture in my mind what should I do and how to start.
Per Physics Forums rules, this isn't going to happen (https://www.physicsforums.com/threads/physics-forums-global-guidelines.414380/, under Homework Guidelines):
Giving Full Answers:
On helping with questions: Any and all assistance given to homework assignments or textbook style exercises should be given only after the questioner has shown some effort in solving the problem. If no attempt is made then the questioner should be asked to provide one before any assistance is given. Under no circumstances should complete solutions be provided to a questioner, whether or not an attempt has been made.
We're happy to help you and guide you, but you need to do the bulk of the work.
D=2GB
Nic=16
Nb | ic =?
Nb | ic = 64/16 = 4
So why don't you use this example and give it a shot with your real numbers. Note: your requires at least two organizations. This implies that there isn't one single correct answer, therefore there might not be an equation to solve
I think that appropriate memory organizations for 4GB memory which is wide 64-bit are:
1.)
4096MB/8=512MB
8*8=64
so first organization should be 8x(512MBx8)
2.)
4096MB/4=1024MB
4*16=64
second one is: 4x(1024MBx16)
is this correct?
