Mesh current analysis with complex impedances
43 replies · 7K views · last reply
i2=(-100i1-j10)/25=-10(10i1-j)/25=-2(10i1-j)/5
i2=-2(10(0.093<-98.86)-j)/5
Honestly I don't know how to continue
shaltera said:
i2=(-100i1-j10)/25=-10(10i1-j)/25=-2(10i1-j10)/5
Okay, but simpler:
##i_2 = -4 i_1 - j\frac{10}{25}##
EDIT: and use the rectangular version of i1 to plug in.
i2=-4(0.093<-98.86)-j10/25=-4(-0.0143+j0.091)-j0.4=0.052-j0.364-j0.4=0.052-j0.764
shaltera said:
Equation above have two unknown,if I replace i1 with 0.093<-98.86 look mess
Only i2 is unknown. Convert i1 to rectangular form before plugging it in.
Note that you should make a habit of keeping more digits in intermediate values! Otherwise repeated conversions and calculations will cause rounding and truncation errors to creep into your results (especially for angular values). Always keep extra guard digits!
0.052-j0.764=sqr(0.0522+(-0.764)2tan -1(-(0.764/0.052)=0.765<-86.106
shaltera said:
0.052-j0.764
What is that? If it's i2 it doesn't look right. Show your steps.
i1=0.093<-98.86
I converted polar form to complex numbers for i1
-0.0143+j0.091 then I entered in
i2=--4i1-j10/25
i2=-4(-0.0143+j0.091)-j0.4=0.052-j0.364-j0.4=0.052-j0.764
i2=0.052-j0.764=sqr(0.0522+(-0.764)2)tan -1(-(0.764/0.052)=0.765<-86.106
shaltera said:
i1=0.093<-98.86
Should be: -0.0143 - j0.0911
Check your conversion. You should note that an angle of -98.86° places it in the third quadrant, so both terms must be negative.
i2=--4i1-j10/25
I calculated with Matlab
for I1=-0.0143-0.0911i=0.0922<-98.9040
for I2= 0.0571-0.0356i=0.0673<-31.9553
I don't get it why we have to calculate by hand?
Can I use Matlab for my assessment?
a=[47+100j 100j;100j 25j]
b=[12;10]
i=a\b
then magn=abs(i)
and then the angle
angle(i)*180/pi
Why do we have to calculate by hand?I'm not living in 20 century
Yes, those values look good. As to why you have to calculate by hand, I can only presume that there are "pedagogical reasons"; You'll have to ask your instructor.
b=[12;10]
i=a\b
then magn=abs(i)
and then the angle
angle(i)*180/pi
Who says you have to calculate by hand? Your instructor? Many instructors will require you to calculate by hand for a while so that you learn how complex arithmetic works. But, after a while, you should be able to use modern software or calculators.
Apart of Matlab, I do not have a calculator with atan2 function.I was looking for a formula to convert polar to rectangular form but all examples are with positive values
Many calculators have built-in polar to rectangular (and back) functions. They will accomplish the same thing.
