Method of Differences for Finding Summation with Fractions - Homework Help
  • Thread starter Thread starter thomas49th
    Method
10 replies · 3K views
thomas49th
I'm given the identity:
[tex]\sum{\frac{r^{3}-r+1}{r(r+1)} \equiv r-1 + \frac{1}{r} - \frac{1}{r+1}[/tex]
EDIT: from r=1 to n on the sum sign
I know I'm ment to use the method of differences and I know that
[tex]\sum(r) = \frac{n(n+1)}{2}[/tex]
I presume you need to find out how you can relate the 3 fractions to the summation of r?
[tex]\sum_{r=1}^n{\frac{r^{3}-r+1}{r(r+1)} \equiv r-1 + \frac{1}{2} - \frac{1}{r+1}[/tex]
Hi thomas49th! :smile:
Hint:
i] r3 - r = … ?
ii] with a view to using differences, 1/r(r+1) = … - … ? :wink:
sorry to of wasted your time but the orginal question was
there is no 1/2
sorry!
Errr can I combine it to this:
[tex]\sum (r) - 1 + \sum(\frac{1}{r} - \frac{1}{r+1})[/tex]
does that help at all?
[tex]\sum(\frac{1}{r} - \frac{1}{r+1})[/tex]
simplifies to [tex]\sum(\frac{1}{r^{2} + r})[/tex]
Thanks! :)
So ∑ 1/(r2 + r) = … ? :smile:
there is no 1/2
sorry!
erm … I could see it was wrong! … in fact, I still think it's wrong! :rolleyes:
Not following you. :confused:
The method of difference involves subtracting the answer for r = n from the answer for r = n-1.
It's question number 4
I could do part a) that's easy just part part b) is giving me trouble.
At first I tried [tex]\sum (r) - 1 + \frac{1}{\sum (r)} - \frac{1}{\sum (r) + 1}[/tex]
but that's wrong?
The ∑n part is right.
The 1 should be ∑1.
The rest is just ∑(1/r - 1/r+1) …
that's already in differences, isn't it? …
so its sum is … ? :smile:
is the sum:
[tex]\frac{n(n+1)}{2} - n + \frac{2}{n(n+1)} - \frac{2}{n(n+1) + 2n}[/tex]
is that right?
is the sum of 1 = n?
thomas49th said:
is the sum:
is that right?
The first two terms are right. :smile:
As I said before: The rest is just ∑(1/r - 1/r+1)
Look … that's (1/1 - 1/2) + (1/2 - 1/3) + (1/3 - 1/4) + …
can you see what's happening?
this is why it's called the method of differences, and why it works!
I know the trick when things cancel out.
So are you substituting values 1 to n into 1/2 - 1/r+1?
how was I ment to spot that you substitute values into there and not the first part?
Thnanks :)
thomas49th said:
So are you substituting values 1 to n into 1/r - 1/r+1?
Exactly! :biggrin:
Because the first part was easy … it was just ∑(r + 1) …
but the second part was ∑ 1/r(r+1), which obviously needs a trick! :smile:
Ahh yes I got it
[tex]\frac{n^3 + n}{2(n+1)}[/tex]
Thank you ever so much :)
