Method of images: infinite line of charge above plate
An infinite line of charge with charge density λ is positioned above a grounded conducting plate, leading to the need to determine the induced charge density σ on the plate. The method of images is applied, treating the system as two infinite line charges: one with density λ above the plate and another with density -λ below it. The potential is calculated using the formula for an infinite line charge, but confusion arises regarding the correct distances for s1 and s2 when evaluating the potential. Clarification is provided that the distances should be expressed relative to the line charge, leading to the correct expressions for s2. The discussion also touches on the thread's movement between forum categories, indicating a potential moderation issue.
zweebna
An infinite line of charge with charge density λ is parallel to and a distance d above an infinite grounded conducting plate. What is the charge density σ that is induced in the plate? For simplicity, consider the line of charge to lie along the line x = 0.
##V_{line} = \frac {\lambda}{2 \pi \epsilon_0} ln(\frac{s_1}{s_2})##
##\sigma = -\epsilon_0 \frac {\delta V}{\delta n}##
So by the method of images, I know this problem is (for z>0) equivalent to an infinite line of charge density λ a distance d above z=0, and an infinite line of charge density -λ a distance d below z=0. I know the potential for an infinite line charge is ##V = \frac {\lambda}{2 \pi \epsilon_0} ln(\frac{s_1}{s_2})##, where I believe ##s_2## would be the distance from the line and ##s_1## is an arbitrary point where ##V \rightarrow 0##. I can then add together the potentials for these line charges:
$$V = \frac {\lambda}{2 \pi \epsilon_0} ln(\frac{s_1}{s_2}) - \frac {\lambda}{2 \pi \epsilon_0} ln(\frac{s_1}{s_2})$$
Now I'm confused. I can't just set the distance ##s_2## to be ##d## as this results in a potential of zero at all points. I can't set one to ##z+d## and one to ##z-d## as that doesn't seem to satisfy boundary conditions (##V=0## when ##z=0##, ##V \rightarrow 0## when ##z \rightarrow \infty##).
I know that once I can get the potential, then I can get the induced charge by taking the partial derivative with respective to ##z## at ##z=0##, but I'm confused about getting the potential.
##s_2## is the distance from the line to the point you want to know the potential at. The ##s_2## in your second term is not the same as that in your first so do not call them the same thing. Instead, express the distance from the point you want to compute the potential for to the lines and use those values.
Likes zweebna
So if the point where we're computing potential is ##0<z<d##, then in the first term it would be ##d-z## and in the second term it would be ##z+d##?PS
What forum should this be in? Since posting it's been moved from intro to advanced, back to intro, and now it's back in advanced.
Are you not forgetting some directions?
Likes zweebna
Ah you're right. So the first time is ##\sqrt{x^2+y^2+(d+z)^2}## and the second term is ##\sqrt{x^2+y^2+(d-z)^2}##? Thank you I think I have it.
Almost, remember that you want the distance to the line charge. What you have given is the distance to a particular point.
Likes zweebna
Ah so since the line is along ##x=0## would I just ignore the y component? So they are ##\sqrt{x^2+(d+z)^2}## and ##\sqrt{x^2+(d-z)^2}##?
Right.
Likes zweebna
Orodruin said:
Right.
Thank you!
I think your thread was used for a forum moderation investigation/experiment which is why it got moved so often. I was the original one who moved it to advanced physics because I felt it belonged here.
