- 22,170
- 3,326
September, schools restart, summer ends, but a new challenge is here:
Ranking here: https://www.physicsforums.com/threads/micromass-big-challenge-ranking.879070/
RULES:
1) In order for a solution to count, a full derivation or proof must be given. Answers with no proof will be ignored.
2) It is fine to use nontrivial results without proof as long as you cite them and as long as it is "common knowledge to all mathematicians". Whether the latter is satisfied will be decided on a case-by-case basis.
3) If you have seen the problem before and remember the solution, you cannot participate in the solution to that problem.
4) You are allowed to use google, wolframalpha or any other resource. However, you are not allowed to search the question directly. So if the question was to solve an integral, you are allowed to obtain numerical answers from software, you are allowed to search for useful integration techniques, but you cannot type in the integral in wolframalpha to see its solution.
ADVANCED CHALLENGES:
1. Show that it is impossible to find four distinct squares as the subsequent elements in an arithmetic progression.
2. SOLVED BY Strants Show that the ##n## roots of a real/complex polynomial of degree ##n## depend continuously on the coefficients.
3. SOLVED BY Erland On a subset ##A## of ##\mathbb{R}## we can apply the operations of complementation ##\mathbb{R}\setminus A## and of closure ##\overline{A}##. By doing this repeatedly one can form for example ##\overline{\mathbb{R}\setminus(\mathbb{R}\setminus A)}##. How many different sets can I maximally generate from ##A## in this manner?
4. SOLVED BY fresh_42 Find the sum of
\frac{1}{\binom{4}{3}} - \frac{1}{\binom{6}{3}} + \frac{1}{\binom{8}{3}} - \frac{1}{\binom{10}{3}} + ...
5. SOLVED BY QuantumQuest Let ##a_k,b_k## be positive real numbers for ##1\leq k\leq n##. Show
\left(\prod_{k=1}^n a_k\right)^{1/n}+\left(\prod_{k=1}^n b_k\right)^{1/n} \leq \left(\prod_{k=1}^n (a_k+b_k)\right)^{1/n}
When does equality hold?
6. SOLVED BY Erland The luckless Daniel (D) is thrown into a circular arena of radius ##a## containing a lion L. Initially, the lion is at the centre O of the arena while Daniel is at the perimeter. Daniel's strategy is to run with his maximum speed ##u## around the perimater. The lion's strategy is to run with speed ##u## in such a way that it remains on the (moving) radius OD. What distance did the lion cover before he caught Daniel?
7. Let ##X## denote the set of all bounded real-valued sequences. As was shown in last challenge, a generalized limit exists for any such sequence. A generalized limit is any function function ##L:X\rightarrow \mathbb{R}## such that
1) ##L((x_n + y_n)_n) = L((x_n)_n) + L((y_n)_n)##
2) ##L((\alpha x_n)_n) = \alpha L((x_n)_n)##
3) ##\liminf_n x_n \leq L((x_n)_n)\leq \limsup_n x_n##
4) If ##x_n\geq 0## for all ##n##, then ##L((x_n)_n)\geq 0##.
5) If ##y_n = x_{n+1}##, then ##L((x_n)_n) = L((y_n)_n)##
6) If ##x_n\rightarrow x##, then ##L((x_n)_n) = x##.
Show that:
a) SOLVED BY Erland There is more than one generalized limit.
b) SOLVED BY Erland For a given bounded real sequence ##(x_n)_n##, we have that every generalized limit ##L## assigns the same value ##l## to this sequence if and only if
\lim_{p\rightarrow +\infty}\frac{x_n + ... + x_{n+p-1}}{p} = l
uniformly in ##n##.
In other words if and only if
\forall\varepsilon>0:~\exists p_0:~\forall p>p_0:~\forall n:~\left|\frac{x_n + ... +x_{n+p-1}}{p} - L\right|<\varepsilon
c) SOLVED BY Erland Find an example of a sequence that does not satisfy the condition in (b) but for which ##\frac{1}{n}\sum_{i=1}^n x_i## does converge.
d) SOLVED BY Erland Show that we can find a generalized limit ##L## such that ##L((x_n)_n) = \lim_{n\rightarrow +\infty} \frac{1}{n}\sum_{i=1}^n x_i## if the limit exists.
8. Let ##p\neq 0## be a real number. Let ##x_1,...,x_n## be positive real numbers, we define the ##p##-mean as
M_p(x_1,...,x_n) = \sqrt[p]{\frac{1}{n}\sum_{i=1}^n x_i^p}
Note that ##M_1(x_1,...,x_n)## is the usual mean.
Prove that for all ##p,q\in \mathbb{R}\cup \{- \infty,+\infty\}## has that ##p\leq q## implies ##M_p(x_1,...,x_n)\leq M_q(x_1,...,x_n)##.
9. SOLVED BY Erland Take rational numbers ##\frac{a}{c}<\frac{b}{d}## with ##a,b,c,d\in \mathbb{N}##.
Prove that if ##bc - ad = 1##, then ##\frac{a+b}{c+d}## is the simplest fraction in ##\left(\frac{a}{c},\frac{b}{d}\right)## in the sense of having the smallest denominator.
PREVIOUS UNSOLVED ADVANCED CHALLENGES:
1. Take a wire stretched between two posts, and have a large number of birds land on it at random. Take a bucket of yellow paint, and for each bird, paint the interval from it to its closest neighbour. The question is: what proportion of the wire will be painted. More strictly: as the number of birds goes to infinity, what is the limit of the expected value of the proportion of painted wire, assuming a uniform probability distribution of birds on the wire.CHALLENGES FOR HIGH SCHOOL AND FIRST YEAR UNIVERSITY:
1. SOLVED BY ProfuselyQuarky You meet a man on the street and he says, “I have two children and one is a son born on a Tuesday.” What is the probability that the other child is also a son?
2. SOLVED BY Math_QED Find and prove a simple formula for the sum
\frac{1^3}{1^4 + 4} - \frac{3^3}{3^4 +4} + \frac{5^3}{5^4 + 4} - ... + \frac{(-1)^n (2n + 1)^3}{(2n+1)^4 + 4}
3. SOLVED BY Biker Consider the function
f(x)=\left\{\begin{array}{l}<br /> e^{-1/x}~\text{if}~x>0\\ 0~\text{if}~x\leq 0\end{array}\right.
a) Show that ##f## is infinitely many times differentiable on ##\mathbb{R}##.
b) Find the Taylor series of ##f## around the point ##0##.
4. Show that for ##0<\lambda<1## and ##\alpha,\beta\geq 0## holds
\alpha^\lambda \beta^{1-\lambda}\leq \lambda \alpha+(1-\lambda)\beta
PREVIOUS CHALLENGES FOR HIGH SCHOOL AND FIRST YEAR UNIVERSITY:
1. On a table are ##2016## bells standing in a sequence. At every turn you have to pick ##2## bells, ring them and then exchange their place.
For example, if there were only ##4## bells, they stand initially as ##A-B-C-D##. In turn ##1##, you pick bells ##A## and ##D##, ring them and exchange them to get ##D-B-C-A##. In turn ##2##, you pick bells ##D## and ##B##, ring them and exchange them to get ##B-D-C-A##.
The goal of the bell ringer is to take ##n## turns after which the sequence of bells is reversed. For example an easy way to reverse the order in ##A-B-C-D## is first to ring ##A## and ##D## to get ##D-B-C-A## and then to ring ##B## and ##C## to get ##D-C-B-A##. We have reversed the bells in ##2## turns.
Show that it is impossible to reverse ##2016## bells in an odd number of turns.
2. Find all ##10##-digit numbers such that
a) each digit ##\{0,1,2,3,4,5,6,7,8,9\}## is used exactly once
b) the first ##n## digits form a number divisible by ##n## (##n\in \{1,2,3,4,5,6,7,8,9,10\}##).
For example, if my number would be ##1234567890##, then ##1## must be divisble by ##1##, ##12## must be divisible by ##2##, ##123## must be divisible by ##3## and so on.
3. Find all 10-digit numbers where the first digit is how many zeros are in the number, the second digit is how many 1s are in the number etc. until the tenth digit which is how many 9s are in the number.
Good luck and thanks for playing!
RULES:
Show that:
uniformly in ##n##.
