Minimum distance required to reach maximum velocity.
The discussion focuses on calculating the minimum distance required for a motor to reach its maximum velocity of 5000°/s with a maximum acceleration of 30000°/s². The relevant physics equation used is v² = u² + ½as, where the initial velocity (u) is 0. It is established that the motor cannot reach maximum speed in a distance of 5°, as it takes approximately 417° to achieve that speed under constant acceleration.
  • Understanding of basic physics equations, specifically kinematics.
  • Familiarity with concepts of velocity and acceleration.
  • Knowledge of angular motion and its calculations.
  • Ability to manipulate and solve algebraic equations.
  • Study the kinematic equations for linear and angular motion.
  • Learn about the implications of constant acceleration in mechanical systems.
  • Explore real-world applications of motor acceleration and velocity in robotics.
  • Investigate the effects of varying acceleration profiles on motor performance.
Engineers, physicists, and robotics enthusiasts who are involved in motor control, performance optimization, and kinematic analysis will benefit from this discussion.
AmazingTrans
Hi there!
I have a basic question here, hopefully someone can brush physics up for me.
I have a motor that is capable of max velocity of 5000°/s, and max acceleration of 30000°/s².
What is the minimum distance that the motor need to travel before it reaches that max velocity?
Can it make it in 5°?
AT
No it can't. For constant acceleration, the equation you need is
$$v^2=u^2+\frac12 as$$
where ##u## and ##v## are initial and final velocity, ##a## is acceleration and ##s## is distance (or angle in this case) travelled.
AmazingTrans said:
Hi there!
AT
A simple way to do this from first principles is:
It takes ##5000/30000 = 1/6## seconds to reach maximum speed at max acceleration.
The average speed during this time will be half the maximum speed. This is ##2500°/s##
The angle rotated during this time is, therefore: ##2500 \times 1/6 = 417°##
Thanks!
  • · Replies 58 ·
