Minimum energy required to escape the grav field
The discussion revolves around calculating the minimum energy required for the Apollo 11 spacecraft to escape the Moon's gravitational field, given its mass and orbital parameters. The subject area includes gravitational physics and energy calculations related to orbital mechanics.
  • The original poster attempts to calculate the kinetic energy and escape velocity but questions the interpretation of "energy required" in the context of the problem. Some participants suggest considering the work needed to transition from the spacecraft's orbit to a point where gravitational forces from the Moon and Earth are balanced.
Participants are exploring different interpretations of the problem, particularly regarding the concept of work and energy in the context of gravitational forces. Guidance has been offered on how to approach the calculation of forces and work, but no consensus has been reached on the exact method to apply.
There is a mention of needing to find the point where the gravitational forces from the Moon and Earth are equal, indicating a potential complexity in the problem setup. The original poster expresses confusion about the requirements of the problem, suggesting a lack of clarity in the assignment.
lizzyb
When it orbited the Moon, the Apollo 11 spacecraft 's mass was 13400 kg, and its mean distance from the Moon's center was 2.56393 X 10^6 m. Assume its orbit was circular and the Moon to be a unform sphere of mass 7.36 X 10^22 kg.
a) Given the gravitational constant G is 6.67259 X 10^-11 N m^2/kg^2, calculate the orbital speed of the spacecraft . DONE
b) What is the minimimum energy required for the craft to leave the orbit and escape the Moon's gravitational field? Anser in units of J.
KE = \frac{1}{2}m v^2
v_{esc} = sqrt{ \frac{2 G M}{R}}
I did this: KE = \frac{1}{2} m_c v^2 = \frac{1}{2} m_c \frac{2 G M_m}{R} = \frac{G M_m m_c }{R}
Where M_m is the mass of the moon and m_c is the mass of the spacecraft .
I plugged in the numbers but the anser was wrong. What else would they mean by energy required? Thanks.
Perhaps they wanted you to find the work required to move the craft from its orbit to the point at which the gravitational force from the moon and Earth are equal and opposite.
how do i go about doing that?
Solve for where the forces are equal. Then, find the work required to move from your current radius to the calculated height.
  • · Replies 16 ·
  • · Replies 30 ·
