Minimum kinetic energy from uncertainty principle
7 replies · 4K views · last reply
sodper
[SOLVED] Help with understanding the uncertainty principle
I may have posted this in the wrong forum. If so I am sure a moderator could move it to the correct one.
Problem statement:
I have an assignment in which I need to calculate the lowest possible mean of an electron's KE , <KE>, based on the uncertainty of the electron's moment.
Given data:
The radius in which the electron is allowed to move, d=2.81*10^-10
Attempt at solution:
The uncertainty of the electrons position corresponds to d, deltax=d
Using the uncertainty principle I got, deltap = hbar/(2*deltax), where deltap is the lowest possible deviation.
I got deltaKE from, deltaKE = deltap^2/(2m), (m is the electron mass)
A fellow student explained to me that because my problem involves a stationary system (an electron bound to an atom), <KE> should be zero, which gives me:
(deltaKE)^2 = <KE^2> - <KE>^2 => (deltaKE)^2 = <KE^2>
But how do I proceed from here?
Problem statement:
Given data:
Ah... the good ol' "fellow student". Unfortunately, the fellow student is often not correct. For a stationary state [itex]\delta <H>[/itex] is zero, not <KE> (where H=KE + PE). The way you were proceeding previously by considering delta p as related to the given delta x looks fine to me.
for example, if the electron is confined to an atom of size 'a' then the KE is roughly
[tex] \frac{\hbar^2}{m a^2}[/tex]
(c.f. particle in a box energy levels (\frac{\hbar^2 \pi^2}{2 m a^2}), etc).
I don't think I quite understand. Did you, as I did, derive the expression for the KE from KE = p^2/(2m) ?
I simply substituted p with deltap to get the min deviation in KE.
I'm not sure how I am supposed use the expression of H.
yeah. that's right.
dont use it for anything; I was just pointing out that in a stationary state it is the *total* energy which has no variance, not the *kinetic* energy.
Ok, but is the expression (deltaKE)^2 = <KE^2> valid?
If so, can I just take the square root to get the mean KE?
no... but we are just getting rough estimates here. That's all that is required. That's why we are using the "equation"
KE "=" (delta p)^2/2m
where (delta p) is given by \hbar divided by (delta x).
I see. Thanks! You've made it a lot clearer.
I'll post again if I need more help.
