Minimum of function under constraint
10 replies · 3K views
mathmari
MHB
Hey! :o
We want to minimize the function $g(x_1, x_2)=2x_1+ x_2$ under the constraint $f(x_1, x_2)=x_1\cdot x_2=18$.
\begin{equation*}x_1\cdot x_2=18 \Rightarrow x_1=\frac{18}{x_2}\end{equation*}
\begin{equation*}\tilde{g}(x_2)=g\left (\frac{18}{x_2}, x_2\right )=2\cdot \frac{18}{x_2}+ x_2= \frac{36}{x_2}+ x_2\end{equation*}
\begin{equation*}\tilde{g}'(x_2)=-\frac{36}{x_2^2}+1=\frac{-36+x_2^2}{x_2^2}\end{equation*}
\begin{equation*}\tilde{g}'(x_2)=0 \Rightarrow \frac{-36+x_2^2}{x_2^2}=0 \Rightarrow -36+x_2^2=0 \Rightarrow x_2^2=36 \Rightarrow x_2=\pm 6\end{equation*}
\begin{equation*}\tilde{g}''(x_2)=-\frac{36}{x_2^2}=\frac{72}{x_2^3}\end{equation*}
For $x=6$ we get $\tilde{g}''(6)=\frac{72}{6^3}=\frac{1}{3}>0$ and for $x=-6$ we get $\tilde{g}''(-6)=\frac{72}{-6^3}=-\frac{1}{3}<0$.
So, $\tilde{g}$ has a minimum at $x_2=6$.
The fuction $g$ has theerfore the minimum at $\left (\frac{18}{x_2}, x_2\right ) =(3, 6)$.
In Wolfram it says that this is the maximum.
What have I done wrong? (Wondering)
The function:
$$f(x)=\frac{36}{x}+x$$
has 2 local extrema, but we need to also look at the range, which is $(-\infty,-6]\,\cup\,[6,\infty)$. You correctly found the local minimum for $0<x$, bur the local maximum for $x<0$ is $-6$. :D
MarkFL said:
The function:
So, do we not get in this case the result using the second derivative test? (Wondering)
You also need to check the boundaries of the function, one of which is $x=0$, at which the function is discontinuous. Another way to find the range of the function $f$ I gave is by writing:
$$fx=36+x^2$$
$$x^2-fx+36=0$$
We then know (from the discriminant) that we require:
$$f^2-12^2\ge0$$
$$(f+12)(f-12)\ge0$$
Hence, we find $f$ is on:
$$(-\infty,-12]\,\cup\,\,[12,\infty)$$
In my haste earlier, I gave the incorrect range.
So, while $f$ has a local min. of $12$ at $x=6$, this is not the global minimum, as the left branch of the function lies wholly below that value, i.e. when $x<0$, then $-\infty<f\le-12$.
How do we find the boundaries? (Wondering)
$$fx=36+x^2$$
$$x^2-fx+36=0$$
$$f^2-12^2\ge0$$
Since $-\infty <f\leq -12$ the function is not bounded from below, is it? (Wondering)
Yes, the function as a whole is not bounded from below or from above. Let's look at this using Lagrange Multipliers...
We have the objective function:
$$f(x,y)=2x+y$$
Subject to the constraint:
$$g(x,y)=xy-18=0$$
We then obtain the system:
$$2=\lambda y$$
$$1=\lambda x$$
This implies:
$$y=2x$$
Substituting this into the constraint yields:
$$x^2=9\implies x=\pm3$$
So, this does yield the two critical points you found by using the constraint to write the objective function in one variable:
$$(\pm3,\pm6)$$
However, these two points correspond only to local extrema, not global. If we turn now to the objective function in one variable:
$$f(x)=2x+\frac{18}{x}=2\cdot\frac{x^2+9}{x}$$
And differentiate while equating the result to zero to obtain critical values:
$$f'(x)=2\left(\frac{2x^2-(1)\left(x^2+9\right)}{x^2}\right)=0$$
$$\frac{x^2-9}{x^2}=0$$
We must observe that we obtain critical values not only when the numerator is zero, but also when the denominator is zero. And we observe that:
$$\lim_{x\to0^{-}}y=-\infty$$
$$\lim_{x\to0^{+}}y=\infty$$
So we therefore may conclude that the objective function has no global extrema. :D
Ah ok! How could we plot this function to see the local extremas? With desmos we cannot, can we? (Wondering)
mathmari said:
Hey! :o
Another way, using "Lagrange multipliers": With $g(x, y)= 2x+ y$ with $f(x, y)= xy$ then $\nabla g= 2\vec{i}+ \vec{j}$ and $\nabla f= y\vec{i}+ x\vec{j}$. At an extremum those gradient vectors must be parallel: $2\vec{i}+ \vec{j}= \lambda(y\vec{i}+ x\vec{j})$. ($\lambda$ is the "Lagrange multiplier".) So we must have $2= \lambda y$ and $1= \lambda x$. Together with the constraint, $xy= 18$, those are three equations to solve for x, y, and $\lambda$. But since a value for $\lambda$ is not necessary for a solution, a good way to start is to eliminate $\lambda$ from those equations by dividing one by the other: $\frac{2}{1}= \frac{y}{x}$ or $y= 2x$. Then $xy= x(2x)= 2x^2= 18$, $x^2= 9$, $x= 3$ or $x= -3$. Only $x= 3$ gives a point in the first quadrant. Further, $y= 2(3)= 6$. The only extremum in the first quadrant is (3, 6). To see that this gives a maximum, not that g(3, 6)= 2(3)+ 6= 12 while g(1, 1)= 2(1)+ 3= 5, a smaller value. The point is that since g(1, 1)< g(3, 6), (3, 6) cannot give a minimum so must give a maximum.
I see! Thank you very much! (Sun)
