Minimum Work Physics Problem | 65 kg Student Climbs 8.0 m Stairway in 12 s
To calculate the minimum work done by a 65 kg student climbing an 8.0 m stairway, the relevant formula is work equals force times distance (w = fd). The force required is greater than the weight of the student, calculated as 65 kg multiplied by 9.8 m/s², resulting in approximately 5096 N. The total work done is then found by multiplying this force by the height of the stairway, yielding a minimum work of about 5100 J. The time taken to climb the stairs does not affect the calculation of work in this context. Understanding the relationship between force, distance, and work is crucial for solving such physics problems.
brentwoodbc
What is the minimum work done when a 65 kg student climbs an 8.0 m-high stairway in 12 s?
v=d/t
v=8/12
v=2/3
v = v2+v1 over 2
2/3 = v2+0 over 2
v2 = 2x[2/3]
v2=4/3
w=deltaEk
w=.5x65x[4/3]^2 - .5x65x0
w = 57 j ?
answer is 5100 j
Hint :work is force times distance. So the time taken does not matter at all.
Edit I get it, trick question lol.
thank you.
brentwoodbc said:
I know
w=fd
f=ma
f=65x9.8
f=5096
but that doesn't have time or distance.
It seems you got the answer!
The minimum work needed would be done by a force acting upward, in the opposite direction of the weight. Its magnitude would have to be greater than the weight, so >65 kg*9.8m/s^2 as you did.
You wrote w=fd, where w is the work, f is the force and d is the distance. Then you said that the formula doesn't have a distance?
Well you've done it :)
haha, i know what I typed wasnt actually what I did.
  • · Replies 16 ·
