Missed analytical opportunities in Bohmian mechanics
376 replies · 37K views
It's not very citable, since it's the basis of most of stochastics: some number of identically prepared independent experiments give as results the outcomes of the same number of i.i.d. stochasts. In this case, I as realist am sure the states exist prior to measurement so they can be seen as outcomes of the preparation.
The problem is the way you express yourself makes it impossible, at least for me, understand. In fact it looks like nonsense to me. For example you reapetedly wrote "the states in the ensemble", which makes no sense whatsoever. It was pointed out by @PeterDonis and you didnt clarify!
We're not talking about "stochastics" here, we're talking about quantum mechanics. Either what you're saying has some basis in either the standard math of QM or some recognized interpretation, or it doesn't.
Again, either this has some basis in the actual math of QM, or it doesn't. What you're describing does not look like QM to me; it looks like classical statistical mechanics. That is off topic in this thread and this forum.
I as realist
Then you're not using the ensemble interpretation and nothing you're saying is relevant to the posts of mine you were responding to, which were specifically about the ensemble interpretation. Realist interpretations make different claims, which are often inconsistent with claims made by the ensemble interpretation. That's not something that is resolvable by discussion. (The guidelines for this subforum talk about this.)
So it appears that "realism of quantum states" predicts that ensemble states are never entangled.
No, it appears that you are trying to mix two different QM interpretations which say inconsistent things. The correct thing is to not do that. You can't take statements that are valid for an ensemble interpretation, such as the ones I made, and then try to interpret them using a realist interpretation. That just leads to nonsense.
WernerQH said:
I have no doubt at all that QT is a statistical theory. But we seem to disagree on what it is about, what it is that causes the perfect correlations observed in so many experiments. I've tried to explain my view in post #309.
I don't know, which correlations you are referring to. Is it about entanglement? This is not so relevant for the very basic question what the state means for an individual quantum system. The standard answer within the statistical interpretation is that the quantum state, represented by a statistical operator ##\hat{\rho}##, is the description of (an equivalence class of) preparation procedures, as in the example with the single electron prepared with pretty sharp momentum (as done in accelerators) in Ballentine's RMP article. The quantum state must have this operational meaning within the statistical interpretation, because otherwise you couldn't associate ensembles, which must be formed by some preparation procedures, with the formal definition of the state in the theory.
Now the association of the state with a real-world situation does imply and only imply the statistical properties for the outcomes of measurements, and in this sense the quantum state describes not the properties of an individual quantum system but of ensembles of "equally prepared" quantum systems. This also implies that observables only take determined values if the system is prepared in a corresponding state, i.e., that with 100% probability you find a specific value. It's something like
$$\hat{\rho}=\sum_{\alpha} p_{\alpha} |a,\alpha \rangle \langle a,\alpha|,$$
where the ##|a,\alpha \rangle## are a orthonormal system spanning the eigenspace ##\text{Eig}(\hat{A},a)## of the self-adjoint operator ##\hat{A}##, representing the observable ##A##, of the eigenvalue, ##a##, and ##\sum_{\alpha} p_{\alpha}=1##, ##\p_{\alpha} \geq 0##.
WernerQH said:
Sorry, I just can't understand your question. I don't see in which sense there should be an inconsistency.
If you deny that the state describes a preparation procedure on a single system, you can't say, how the well-defined ensembles, described by a statistical operator ##\hat{\rho}## are formed. I also don't understand, why the standard definition as describing a preparation procedure on a single system should be problematic. It's just reflecting what's done by experimentalists: They prepare large ensembles of equaly prepared individual quantum systems and perform measurements on them. The probabilistic predictions of QT are confirmed by these experiments. So there must be some truth in the standard association of quantum states with the ability to form ensembles with the corresponding specific, statistical properties.
WernerQH said:
Also experiments with single particles involve many events, taking a lot of time in the lab.
Exactly. To be able to do so, it must be possible to prepare ensembles in a well-defined quantum state, and the preparation procedure refers to the single members of these ensembles.
So is the idea that each state in an ensemble is given by a copy of the same stochastic variable? Where the space of possible outcomes of each of these stochastic variables is (perhaps) a subspace of all possible quantum states for these specific quanta?
Standard QT is not described by stochastic differential equations. I don't see, where you find "stochastic variables" in the theory.
@vanhees71 I think your favorite interpretation, which you call the minimal statistical interpretation, is not the ensemble interpretation. It is the minimal interpretation of the formalism of QM including the statistical interpretation of the state vector (via the Born rule). But it is not a statistical interpretation.
Then, what do you think differs in what you call "my interpretation" to that one given by Ballentine. I don't see any difference.
For you the state vector is a description of the individual system. If you have many equally prepared ones, they will have the same state vector. But that is not the same as the state vector describes the whole ensemble and not the individuals.
vanhees71 said:
If you deny that the state describes a preparation procedure on a single system, you can't say, how the well-defined ensembles, described by a statistical operator are formed.
The problem is your imprecise use of the term "single system". Of course a polarization filter will produce a beam of photons in some definite polarization state. Subsequent measurements with a polarizer in the same direction will confirm that the photons are in this same state. But the word "state" refers to an abstraction, a "typical" or "average" photon in that beam. It is an assumption that the state is a complete description of each photon in that beam. I'm not proposing hidden variables, but we cannot prove that the photons in the beam are identical. So the second best option is to think of the polarization state as a stable statistical distribution that doesn't change if we add more polarization filters with the same orientation. It still describes an ensemble. Classically circularly polarized light is characterized by a correlation of ## E_x ## with ## E_y ## at some point in space a quarter period later. This carries over to the microscopic, quantum picture. (See, for example, my post in another thread.)
No! It's not that superficial. It's precisely as you say, and that's what I say the whole time: The state (not the state vector but the statistical operator ##\hat{\rho}## btw.) describes on the one hand for the single system a preparation procedure but on the other concerning the properties of the so prepared system probabilities for the outcome of measurements and nothing else, which implies that it describes properties of the ensemble an not the individual system.
Of course you need both meanings of the state, i.e., it must refer to the single system as a description of the preparation procedure, because otherwise you couldn't make the connection between the formalism (statistical operator) with the system under consideration. At the same time the preparation in a state only provides probabilistic properties and as such make only sense for an ensemble of so (sic!) prepared systems.
While I won't try to give labels to these positions, I will at least point out that these two positions are distinct:
i) Given a single microscopic system, a state represents an equivalence class of preparations the system was subject to.
ii) Given a single microscopic system, a state represents a fictitious infinite ensemble of equivalently prepared systems, of which the system is a member.
I think both statements are correct and both are necessary to make physical sense of the quantum formalism, and both are part of the minimal statistical interpretation a la Balentine.
i) Is an account given by Asher Peres, and might be too minimalist even for Balentine.
But in both cases, the "state as an ensemble" will be tested by a series of individual measurements events, that cannot be reduced nor averaged.
"equivalence class of preparations" is quite vague, as it cannot be equivalent as defined by QM itself (no cloning). Either way that ensemble is the most non-local thing there is in physics.
  • Skeptical
The point is you must be able to build ensembles in the lab to begin with and indeed this is done by some "preparation procedure" on each single system, and the quantum state, ##\hat{\rho}##, thus refers to the preparation procedure and in this respect refers to the single system. On the other hand what it also describes are the properties of the system due to this preparation procedure, i.e., what this preparation implies concerning the outcome of measurements/observations on each of the so prepared systems. Now in the development of the theory it turned out that the only concistent interpretation is Born's probabilistic meaning of the state, and in this sense the state refers only to an "ensemble of equally prepared systems", i.e., you need to be able to prepare the system in this state in a reproducible way.
vanhees71 said:
The point is you must be able to build ensembles in the lab to begin with and indeed this is done by some "preparation procedure" on each single system, ...
What does it mean to "build ensembles"? I think you've got this backwards: it is Nature providing the ensembles, and we struggle to adjust our statistical descriptions to what we observe. A preparation procedure is empirically known to have produced specific statistical patterns in the past, and it is reasonable to assume that it will produce the same patterns in the future. Of course it is possible to apply probability theory to a "single" system, e.g. the throw of a die. But it's still statistical reasoning. The definiteness of the "state" of the "system" is more grounded in psychology than in the quantum formalism: your desire to describe it in a "Newtonian" way as a system evolving continuously with time, rather than a sequence of events.
Quantum theory has a vastly broader scope than experiments in the laboratory. (Consider for example the nuclear reactions in the sun.) Isn't it ridiculous to base the formulation of this microscopic theory on undefined (primitive) notions like state preparation and measurement? On the grounds that there is no other way to describe the real world?
  • Sad
  • Skeptical
Well, yes. Nature provides also some kind of ensembles. In our everyday life it's many-body systems close to thermal equilibrium. Here, of course, we have to deal with the question, how to describe systems with incomplete, coarse-grained knowledge about the state, and that's why there thermodynamics plays such an important role.
Otherwise physics deals with quite artificial idealized "preparations" in order to investigate aspects of Nature under controlled conditions. E.g., in Bell experiments one prepares entangled photon pairs by parametric down conversion with help of a laser shot at BBO crystals and filtering out precisely these entangled pairs.
With a single throw of a die you cannot say anything about the statistics. You have to throw the die many times in the same way to get statistics to empirically check predicted probability distributions. E.g., just knowing nothing about the die you simply assume that's a fair die and you assume P=1/6 for each of the possible outcomes. You can test this hypothesis of course only by repeating the experiment very often, i.e., probabilistic statements are about ensembles.
I know there's all this philosophical sophistication about some "Bayesian approach" to probabilities, but this is completely, well, philosophical, i.e., it doesn't say, how to figure out whether the predicted probabilities of some theory are correct for the given situation/preparation procedure.
There's no problem whatsoever to apply the formalism to the fusion processes in the Sun. This is done since Bethe et al in the 30ies. To confirm the "solar standard model", of course needed till the mid to late 1990ies, when neutrino mass and oscillation was discovered, but that's another story.
We all know that. You are refusing to answer my question. Is it too embarrassing?
I obviously don't understand the question. The state of the matter in the Sun is that of a plasma close to thermal equilibrium, and you have thus a well-"prepared state" you can do calculations with. Where do you think contradicts this example in any way the here discussed statistical/ensemble interpreation of Q(F)T?
I thought state preparation is something physical, brought about by an experimenter in the real world. Apparently for you it can also be something that happens in the mind of a theorist. Never mind.
The Sun is also the result of a "preparation process" in the sense we are discussing it here. Of course, it's not prepared by a human being in the lab, but that is completely irrelevant to the discussion about the formal meaning of the quantum state within the ensemble interpretation.
Your use of the term "preparation process" is so general as to render it meaningless. I don't see how this clarifies the "formal meaning of the quantum state". Merely reiterating these anthropomorphic terms doesn't make them precise. After decades of mutual indoctrination physicists have learned to apply quantum theory and have become accustomed to the required mental gymnastics. You may think that the formulation of the theory leaves nothing to be desired, but this is a view I do do not share.
So what's your "definition of the quantum state"? For me the ensemble interpretation is the most simple and close to what's really done in physics.
We agree on the mathematical definition. My concern is how it relates to the real world. But for you this is probably a merely philosophical question :-)
Yes.
This is way too restrictive. Natural processes that happen without humans being involved can count as state preparations. Otherwise QM would be limited to predicting what can happen in human laboratories.
Unknown state cannot be cloned. Known state can be cloned. When the preparation is known, the state is known.
Statements like "that is merely philosophy" or "that is just mathematics" have the problem that both disciplines are huge, hence such a statement either contains very little information, or else risks to denigrate huge complex academic fields.
Pauli accusing Bohmian mechanics (and other opposition to Copenhagen) as resulting from "metaphysical prejudices" doesn't suffer from that problem. Not sure how helpful it would be to blame religion, psychology, or ethics (seen as subfield of philosophy) instead, to classify some unresolvable conflict. The risk to devalue serious human endeavors remains.
Still, I guess it would help me if "merely philosophical question" would be replaced by something more concrete, like metaphysics, metamathematics, linguistics, or maybe also postmodern nonsense, continental philosophy, ... whatever drew your scorn.
