Mistake in Schaum's Group Theory?
52 replies · 7K views
WWGD said:
Maybe one way of doing the proof for (fin. dim) V.S is to use the fact that, given an ordered basis ## \{ v_1, v_2,...,v_n \} ## there is an isomorphism between ##\text L(V,V) ## and ##\text Mat_{(n,n)}##. And then you can show a matrix can only have 2-sided inverses, meaning it has to describe a map that is 1-1 and onto.
##AB=I B=A^{-1} \rightarrow BA =A^{-1}A=I ##
So B is both right- and left- inverse and we have two-sided inverses.
BAH. My argument here is incorrect; it does not automatically follow. It is an interesting exercise: Show that for A,B same size, AB=I , then BA=I. Not trivial that matrix inverses are necessarily two-sided. EDIT: I don't know if/how this can be generalized to non-commutative rings with identity: if rr'=1 , when does it follow that r'r=1?
an easy way to do this for ##n## x ##n## matrices is write the left inverse of ##B## as a linear combination of powers of ##B## (i.e. a polynomial in B). Now right multiply by ##B## and each side is thus equal to the identity matrix, but your polynomial commutes with ##B## (evaluate term by term) which means your left inverse commutes with ##B## as well and hence is an actual inverse.
The "easy" polynomial for the above uses Cayley Hamilton. The much more basic result that is actually useful here is that these matrices live in a vectors space with dimension ##n^2## and hence there must be some monic polynomial of degree (at most) ##n^2## that annhilates them... once use you have your polynomial in B equal to zero, multiply on the left by the left inverse of ##B## a suitable number of times and move the lowest order term (the left inverse of B itself), to the right hand side, and rescale as needed. (This is where the first paragraph starts.)
##AB= I\implies BA = B(AB)B^{-1} = BB^{-1}= I##
An inverse exists by a determinant argument: ##AB=I## means that ##\det B \neq 0 \neq \det A##
In general in non-commutative rings ##rr'=1## does not imply ##r'r=1##. See e.g. here https://math.stackexchange.com/q/70777/661543
Yes, but you cheated a bit: the multiplicity of the determinant, the existence of ##B^{-1}## as left and right inverse, which is what we wanted to show! The condition does not hold in arbitrary rings, but in groups. So the essential question behind the task was: Can we show that ##GL(V)## is a group and thus ##AB=I \Longrightarrow BA=I## without using linear algebra? It's easy if there exists a left inverse, but the existence will probably require facts from the definition of the group. Can this be proven, or can we conclude the existence of ##CA=I## only from ##AB=I\,##?
##BABB^{-1} =I ## implies ##AB=AB^{-1} ## , not necessarily the identity. Maybe we can argue:
##BA=I ## , then ##AB= ABAB=I \rightarrow (AB)^n =I ## , has only identity as solution ( since this is true for all natural ##n## )?
You said earlier that ##AB=I## is given. I think you confused the order now. This is very confusing, as the order is all we talk about. But given ##AB=I## the following doesn't make much sense:
If we allow a left inverse ##CA=I## then we immediately have ##B=IB=(CA)B=C(AB)=CI=C##. The existence of ##C## is the problem. To write it as ##B^{-1}## is cheating.
Yes, my bad, mixed both things up. Let me go for another doppio, a 2-sided doppio. I intended a post to contain left- and right - inverses, but I somehow got logged off a few times and lost track of what I was doing :(.
WWGD said:
Ok, this is the argument I intended:
Assume ##AB=I ##
Then ##BA=B(AB)A=(BA)^2=I ## ( just need associativity) and we can extend to ##(BA)^n =I ## for all n
That's wrong. If ##BA=C## then all we have is ##C=BA=B(AB)A = (BA)^2=C^2## and per recursion ##C=C^n## for all ##n##. Since there are unipotent matrices which are not the identity, I don't see how ##C=I## should follow.
Yes, use BA or C either way. And, no, not . ##C^n =C ## for _some_ n, but ##C^n =C ## _for all_ n . Do you have a non-ID C with ##C^2=C^3=...=C^n =I ## ? Maybe, I don't know of one. Also DetC =1 here, let's assume Real entries. If not, the determinant is a 2nd, 3rd,...n-th,... root of unity. Is there such number?
That's what I said, for all ##n##. And, no, I don't have such a ##C##, but this isn't a formal proof, especially if we do not use linear algebra.
Yes, I know, I never said it is a proof. But this matrix BA satisfies infinitely many polynomials ##C^n-C =0 ##, which is also strange, but, I admit, not a proof (yet?).
Well, we have ##C=0## is a solution, too. And theoretically we can have zero divisors from the left and not from the right and similar nasty things. But the question "can we prove ##G=GL(V)## is a group" without using linear algebra, and only ##AB=I## is probably doomed to fail, as @Math_QED mentioned correctly, that it doesn't work in rings. But if it's a group, then we are done. If we do not allow this, we have to use something from the definition of ##G##, and that is linear algebra.
C=0 Is not a solution ##AB=I ## so ##Det(AB)=DetADetB=1 ## , and ##DetC=DetBA =1 ## , but Det0=0. EDIT: ##DetC =1 ##or if you allow Complexes and ##Detc \neq 1##, DetC is a 2nd,3rd,..., nth,... root of unity.
WWGD said:
C=0 Is not a solution AB=I so Det(AB)=DetADetB=1 , and Det0 =0.
We are still on the necessity part. The damn existence of ##C## is the problem. And ##0## is a solution to ##C=C^n## for all ##n##. If you use the determinant, you have to mention the field! What I say: we will need some argument from LA. In the end we could simply write down the formula for the inverse in terms of ##A## and good is.
Well, yes, no finite fields, so C^n=C. And I had specified Complexes or Reals. Anyway, I don't see how this relates to Los Angeles, LA ;), but at any rate, I think we may be able to relax condition of linearity. All we need is scaling property and showing the image is not meager, i.e. the image contains a ball about the origin , then if we consider a line segment y=cx from the origin, we consider the multiples of that segment and every point is hit in that way.
fresh_42 said:
##(0,1) \stackrel{\operatorname{id}}{\hookrightarrow} \mathbb{R}-\{\,0\,\}\stackrel{\varphi}{\rightarrowtail} (-\frac{1}{4},\frac{1}{4}) -\{\,0\,\} \stackrel{+\frac{1}{3}}{\hookrightarrow} (0,1)##
where I only need a bijection ##\varphi## between the real line and an open interval, both without zero to make it easier.
If I understand what your notation conveys, the last bit should be ## \stackrel{+\frac{1}{4}}{\hookrightarrow} (0,1)##, since you're adding 1/4 to each element of the punctured interval (-1/4, 1/4).
No, I just wanted to shift it into the interval injectively. The amount didn't matter. With ##\frac{1}{4}## I would have had to deal with the zero, which I avoided by taking ##\frac{1}{3}##.
fresh_42 said:
We still have the difficulty that zero divisors are possible as long as we haven't a group. The (unique) solvability of ##x A = B## is equivalent to the group axioms, so we circle around the main topic. Guess we have to visit La La Land.
Where are you getting your scalars? We're talking coefficients in a field of characteristic zero now, aren't we?
