Modeling a Control System using Transfer Functions
The discussion revolves around modeling a control system using transfer functions, specifically focusing on the preamplifier and the associated block diagram. Participants are attempting to derive transfer functions and clarify the relationship between physical blocks and their corresponding transfer functions.
  • Homework-related
  • One participant expresses uncertainty about the relevant equations needed to solve the problem and attempts to derive the output of the preamplifier.
  • Another participant suggests that K is a fixed value and that the transfer function should represent the output over the input, indicating that the preamp's transfer function would simply be K.
  • There is confusion regarding the concept of the "forward chain" and the multiplication of gains, with participants seeking clarification on these terms.
  • One participant points out that the open-loop transfer function should be derived from the product of the blocks in the forward path, questioning the necessity of feedback in this context.
  • Some participants express uncertainty about whether to derive the open-loop or closed-loop transfer function, indicating a potential misunderstanding of the problem requirements.
  • Questions arise about how to fill out the table for each block and the distinction between the physical block and the transfer function.
  • Clarification is provided that the gain of the block is equivalent to the transfer function by definition, but confusion persists regarding the table's request for both terms.
Participants do not reach a consensus on the approach to take regarding open-loop versus closed-loop transfer functions, and there is ongoing confusion about terminology and the requirements of the homework assignment.
Participants express varying levels of familiarity with block diagrams and transfer functions, indicating that some foundational knowledge may be lacking. There are unresolved questions about the definitions and roles of blocks and transfer functions in the context of the assignment.
yaro99
[/B]
Listed under 2.1 in the image above.
This is the only relevant equation that I'm aware of, but I'm almost sure that there is something else I need to know before I can solve the problem.
I tried solving for the preamplifier first, then I realized I was just running around in circles and not actually solving anything.In order to get V_e(s), I need to first find the output of the first potentiometer and subtract it from that of the second one.
output for first potentiometer: K_pot*θ_i(s)
output for second potentiometer: K_pot*θ_a(s)
V_e(s) = K_pot(θ_i(s)-θ_a(s))
Now, V_p(s) = K*V_e(s) = K*K_pot(θ_i(s)-θ_a(s))
Transfer function of preamplifier: [K*K_pot(θ_i(s)-θ_a(s))]/[K_pot(θ_i(s)-θ_a(s))] = K
Clearly the transfer function is not the same thing as the function for the physical block, so I must be doing something wrong here. I just don't see how I can fill out the table using just the equation I was given.
it looks like you have a fundamental misunderstanding of what transfer function you are solving for.
K is typically a fixed value that you choose (using a technique like root locus for example)
When you are told you need to sole for a transfer function, typically you solve for the output over the input (azimuth angle over desired azimuth angle). so your transfer function for the preamp would simply be K
there are many ways to do that. two simple ways are the mason gain formula and simple block diagram algebra.
https://en.wikipedia.org/wiki/Mason's_gain_formula you can follow this if you want to do masons gain
block diagram algebra for a problem like this is simple:
V_e=V_i-theta_o*K_pot_2 ...as you already mentioned
simply multiply that by the forward chain until you get to your output. then manipulate the equation so you have your output over your input
give it a shot
I don't understand this part, forgive my ignorance. Why am I multiplying, and what is the forward chain? We are talking about just the preamp here right?
I must admit that I do not completely understand the problem:
1.) All the transfer functions of the variuous blocks are given in the Block diagram
2.) Where is Block 6 (integrator)?
3.) As far as I understand, you are required (according to 2.1) to derive the "open-loop transfer function".. That is the transfer function between input and output WITHOUT any feedback. Hence, it is simply the product of the shown 5 Blocks in the forward path.
So - what is the problem?
just multiply the gains of the the blocks.
but as LvW pointed out, I may have a misunderstanding as well. I assumed you need to take the closed loop transfer function, but you might need to take the open loop transfer function. with open loop it becomes much easier
How would I do this for each particular block? I am supposed to fill out the table for each one.
Also, in the table, what would be the difference between the Block and the Transfer Function?
how much experience do you have with block diagrams?
looking at V_e and V_p, by definition V_p=V_e*preamp which is V_p=V_e*K
the gain of the block is the transfer function of the block by definition
Not much. My professor gave us one (bad) lecture on them and then gave us this HW. We are supposed to look up transfer functions on our own but my book was unhelpful.
That's what confused me. If that's true then I'm wondering why the table asks for both.
so for one line of the table
physical black=preamp
tranfer function=k
input=v_e
output=v_p
i would interpret block as the name, not the transfer function
