Model Pendulum w/ Damping: Newton's Laws & Rubber Band
  • Thread starter Thread starter bsmith6661
    Modeling Pendulum
To model a pendulum with damping connected to a rubber band, it is essential to apply Newton's Laws while considering the properties of the rubber band. For small displacements, the rubber band can be approximated as a linear spring, but it exhibits nonlinear behavior for larger displacements. The rubber band will only be taut when the pendulum is displaced to the left, which must be factored into the equations of motion. Gravity will consistently influence the pendulum's movement regardless of the displacement direction. Properly accounting for these elements will lead to an accurate model of the system.
bsmith6661
I feel like this is a dumb question, but here goes: I'm trying to model a pendulum with damping. The pendulum is connected to a rubber band (unstretched when the pendulum is vertical) on the right side, and the rubber band is fixed at the other end. How would I go about modeling a rubber band using Newton's Laws? Everything needs to be in terms of m, k, and c. I know that a rubber band acts similarly to a spring, but can it be modeled as such?
For very small displacements, the rubber band will act approximately like a spring. For larger displacements, you will find that the rubber band is nonlinear. From you description of the system, it sounds like the rubber band will only be taut for displacements to the left. You will need to take that into account when you write the equation of motion. Gravity, of course, will act no matter which direction the pendulum is displaced.
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 35 ·
  • · Replies 16 ·
  • · Replies 45 ·
  • · Replies 17 ·
