Modeling the Kaluza-Klein theory
  • Level: Undergrad
  • Thread starter Thread starter AnselmsApprentice
    Dimension Geometry
12 replies · 10K views · last reply
AnselmsApprentice
I am a retired lawyer who has been pondering tiny 5th dimensions since I first heard about them in 1986. I think I sort of understand the Kaluza-Klein theory in a geometrical sense. I'm trying to connect the dots of what I think I understand to what the standard model predicts. Does anybody here understand the Kaluza-Klein theory?
Kaluza-Klein theory is not part of our best current physical theories. It was an attempt to unify electrodynamics and gravitation, but it did not pan out.
Kaluza-Klein models are actively being considered as potential extensions of the Standard Model. Some of the phenomenology include dark matter candidates collider signatures of KK-excited modes. The original idea of unifying gravity and electrodynamics may not be viable, but that doesn't mean KK-theory in a broader sense is dead.
Can you give some references? I suspect the term "Kaluza-Klein models" is being used in this area of research in a very general sense, and I don't know if that general class of models is what the OP is asking about. The term "tiny 5th dimensions" in the OP suggests to me that the original Kaluza-Klein model is specifically what is being asked about.
https://iopscience.iop.org/article/10.1088/1475-7516/2010/01/018
There should be further references within. See also
https://inspirehep.net/literature?sort=mostrecent&size=25&page=1&q=F t kaluza
Models such as those leading to dark matter candidates specifically deal with tiny extra dimensions. The 5-dimensional fields are expanded into their momentum modes, which results in particles having Kaluza-Klein towers of similar particles - just with a higher 4-dimensional effective mass due to the additional momentum in the extra dimension(s). Effectively ##m_5^2 = E^2 - P^2 = E^2 - p^2 - p_5^2## leads to ##m_4^2 \equiv m_5^2 + p_5^2 = E^2 - p^2## where ##P## is the full 5-dimensional momentum, ##m_d## the ##d##-dimensional mass, ##p## the momentum in the large dimensions and ##p_5## the momentum in the extra dimensions. The latter is discretized due to the compact nature of the extra dimensions and the exact spectrum depends on the compactification.
The phenomenology of KKDM is quite similar to that of R-parity SUSY DM. The R-parity equivalent essentially results from momentum conservation in the extra dimensions. Often an orbifold compactification is assumed so momentum is not actually conserved as such, but instead a KK parity remains - essentially preventing decay of the first KK modes.
Yes, but more than just one, as in the original KK theory.
Not necessarily. Orbifold compactification of a single extra dimension remains popular.
Regarding the original question about Kaluza-Klein and the standard model:
Up until World War 2, the only known fundamental forces were gravitation and electromagnetism. If we focus just on the force fields, the simplest version of Kaluza-Klein unification - 5d Einstein gravity, with the fifth dimension forming a small circle - gives you 4d gravity, an electromagnetic field (from the metric components relating the first four dimensions to the fifth), and a new scalar field corresponding to the size of the fifth dimension.
Postwar physics eventually yielded knowledge of two new forces, the strong nuclear force and the weak nuclear force, described by generalizations of Maxwell's equations, the Yang-Mills equations. And it turns out that if you have seven extra dimensions in the right shape (a 7-dimensional manifold whose "isometry group" is the same as the "gauge groups" of the standard model, SU(3) x SU(2) x U(1)), you can get *all* the non-gravitational force fields from components of the 11-dimensional metric (in effect, from the quiverings of the 7-dimensional manifold). It's an amazing thing because 11 is the number of dimensions in one of the natural candidates for theory of everything, maximal supergravity (which today we would understand to be an approximation to M-theory, the 11-dimensional version of string theory in which all the strings have become 2-dimensional blobs called M2-branes).
However, the Achilles heel for Kaluza-Klein has always been matter. In its original form, when it wasn't even quantum mechanical, matter particles were imagined to be point particles following the 5d version of the "geodesic equation", the equation in general relativity which describes e.g. how orbits arise by following the shortest path in curved space. The concept was that a particle would be moving through the 4 large dimensions, and around and around the 5th dimension, and charge would be related to that 5th-dimensional motion. Interpreted thus, the part of Maxwell's equations which describe how a charged particle responds to the electromagnetic field are reproduced, but the actual values for charge and mass are related in ways that are completely wrong.
Meanwhile, when it comes to the nuclear forces, the interaction of a particle with the Yang-Mills fields is described by Wong's equations. I don't actually know for sure if geodesic motion in the multiple extra dimensions of these more complicated Kaluza-Klein spaces, reproduces Wong's equations. Probably it does, but at this point we can't ignore quantum mechanics any more, e.g. the interactions of quarks with gluons are very quantum-mechanical.
So instead of looking at the geodesic motion of a point particle, we have to consider fermionic quantum fields, from which matter particles arise as quanta. We also want these matter particles to be fundamentally massless, since that's how the standard model works - the massive particles we observe, consist of massless left-handed "Weyl fermions" coupled to massless right-handed Weyl fermions via the Higgs field, producing massive "Dirac fermions" with both left- and right-handed states. It's a little intricate but that's how we understand what experiment shows us.
This means that in a quantum Kaluza-Klein model, instead of trying to fiddle with the geodesic equation so that the masses and charges come out right, you want the Kaluza-Klein "zero modes" of your 11-dimensional fermionic field (the zero modes are a kind of harmonic of the field in the 7 compact dimensions) to have the correct interactions with the metric (in particle physics terms, they must belong to the correct representations of the gauge groups, to match the matter fields of the standard model).
And *this* is the thing that no modern Kaluza-Klein theorist ever managed to work out. The fundamental problem is that in the standard model, the left-handed and right-handed Weyl fermions interact differently - the left-handed ones interact with the weak force, the right-handed ones do not. But the components of the 11-dimensional fermion field, when compactified, must behave the same, regardless of their 4-dimensional handedness.
So you may ask, what's going on with all the extra dimensions in string theory, then? The answer is that they are not being used in that way. In a true Kaluza-Klein theory, the shape of the extra dimensions has a symmetry (an "isometry") and the non-gravitational force fields are produced by vibrations of the extra dimensions. The Calabi-Yau spaces used in string theory do not have isometries, they don't have that kind of vibration. They do have size parameters which can be excited, producing particles called "moduli" which remain completely undetected. In string theory, the non-gravitational forces are produced in other ways possible only for strings rather than point particles (either by "open strings" whose endpoints are attached to parallel branes, or by special closed strings that carry charges on them).
However, Kaluza-Klein behavior is possible in string theory, if the extra dimensions do contain an isometry after all (e.g. if one of them forms a circle that can expand and contract). And indeed, similar to what @Orodruin mentioned, there is a class of string theory models in which one of the extra dimensions (called the "dark dimension") behaves that way, and thereby produces dark matter.
Now I should say that Kaluza-Klein theories have never been completely abandoned. The concept is there as a permanent possibility, and there's always a few people still trying to make it work. But when the modern wave of interest in extra dimensions began in the 1970s, the concept was deeply explored and the mainstream of model-building abandoned it, essentially because of the problem of how to get matter that behaves differently according to its handedness ("chiral fermions"). It must have been hard to abandon because there are just some really striking properties of isometric compactifications of 11-dimensional supergravity. The simplest one, compactifications on a 7-sphere, produces "N=8 supergravity" in four dimensions, a theory which comes tantalizingly close to the standard model in certain respects. People really wanted one of those 7-manifolds with a standard model isometry group to do the job, but the problem of the chiral fermions seemed to be insurmountable.
One attitude is to say, well, string theory or M-theory is probably the real theory of everything, and it's a very rich theory, it contains the potential for Kaluza-Klein behavior but it also contains so much more, and it would be a mistake to get sentimentally attached to the idea that the non-gravitational forces (the gauge fields) should come from Kaluza-Klein and nothing else. Modern theoretical physics allows for a very large number of possible constructions; many of them have very appealing or striking features; but only one of them can be right. Maybe that neat coincidence that the standard model needs seven extra Kaluza-Klein dimensions, and M-theory has four plus seven dimensions, is just a coincidence. Or, maybe there's an unrecognized loophole and you can get chiral fermions after all. (Edward Witten, in a highly cited 1981 paper which goes into the problem, concludes by speculating that an additional effect called torsion might make a difference.)
Where is F theory with regards to M and the other 5 string theories?
Out of curiosity one wants to add another dimension of time (which could hypothetically run counter to your clock), but the problem is that the PDEs aren't stable; You might of heard of the ultra-hyperbolic wave equation. (It was suggested to me as an MSc thesis project but didn't finish working on it since my adviser is/was emeritus).
Let me start by saying of M-theory and the 5 superstring theories, that M-theory is an 11-dimensional theory of branes, that is only partly worked out, but which appears capable of reducing to all the 10-dimensional superstring theories, in various limits and/or after a duality transform.
On the other hand, speaking conservatively, F-theory is just a calculus or formalism for describing the 10-dimensional Type IIB superstring at strong coupling. It is described as 12-dimensional, because one is treating a complex-valued quantity defined throughout the 10 dimensions (the VEV of the axio-dilaton) as in fact describing the shape (ellipticity and skew) of a 2-dimensional torus. So for example, if your original IIB spacetime has four large dimensions, and compact dimensions in the form of a 6-dimensional Calabi-Yau, you can geometrically describe a varying axio-dilaton VEV by "fiberings" the 6d CY with 2d tori, leading to an 8d Calabi-Yau.
However, those two extra dimensions are regarded as infinitesimal. They don't add to the volume if you integrate, for example - unlike the 11th dimension of M-theory. They simply allow the effects of the axio-dilaton to be packaged together with the Calabi-Yau geometry... Regarding the infamous "second time dimension" of F-theory, I get the impression from a comment by Lubos Motl that in some respects, the two extra infinitesimal dimensions are both regarded as spacelike, and the (10,2) signature only applies to the spinorial part of F-theory calculations. But all I can honestly say is that I don't know how this part works.
Another clue: M-theory is the strong coupling limit of the Type IIA string. The 11th dimension becomes finite in size as you go to strong coupling. F-theory, meanwhile, describes the Type IIB string at strong coupling. It gets *two* extra dimensions, but both are infinitesimal. Meanwhile, IIA and IIB are T-dual, and therefore, in some sense, so are M-theory and F-theory. If you can figure all that out, you can probably get a much better idea of how F-theory works.
Some final comments: I've noticed that Warren Siegel has a more ambitious concept of F-theory, part of a discourse in which he freely talks about relationships between M-theory, F-theory, S-theory (S for string), and T-theory (T for T-dual). I actually can't follow it at all, and he might still be on a wrong track even though he is an accomplished string theorist, but if there is a deeper meaning to F-theory, he might have a hold of it.
Final final comment: One might also want to ask whether the extra dimensions of F-theory, have anything to do with the extra dimensions of bosonic string theory, the original non-supersymmetric string theory with 26 rather than 10 dimensions. Bosonic string theory actually has relations with superstring theory, there are cosmological solutions due to Hellerman and Swanson that interpolate between the two theories, but time-varying string theory is not very well understood (even though that is what we need to understand an expanding universe!). But I would want to complete my understanding of the IIA, IIB, M, F web, before trying to understand how F-theory relates to the bosonic string.
My take on this. The fundamental reading is the collection of papers
Modern Kaluza-Klein Theories​
Portada
and inside of them, the most fundamental is Witten 1981
  • "Search for a Realistic Kaluza-Klein Theory"
Because it sets the framework to do non abelian gauge theories.
A immediate reaction to it is Salam-Strathdee, and then a lot of work trying to classify the new compactifications and getting relations between coupling constants. A lot of heavy thinkers entered the game, even if in theory it was killed by Witten itself with his paper on fermions, shelter island II.
edited by Thomas Appelquist, Alan Chodos and Peter George Oliver Freund.
  • CHAPTER II. HISTORY​
  • Gunnar Nordström, "On the Possibility of a Unification of the Electromagnetic and Gravitation Fields"
    50
  • Gunnar Nordström, "Über die Möglichkeit, das elektromagnetische Feld und das Gravitationsfeld zu vereinigen"
    57
  • Th. Kaluza, "On the Unity Problem of Physics"
    61
  • Th. Kaluza, "Zum Unitätsproblem der Physik"
    69
  • O. Klein, "Quantum Theory and Five Dimensional Theory of Relativity"
    76
  • O. Klein, "The Atomicity of Electricity as a Quantum Theory Law"
    88
  • A. Einstein and P. Bergmann, "On a Generalization of Kaluza’s Theory of Electricity"
    89
  • Y. Thiry, "The Equations of Kaluza’s Unified Theory"
    108
  • Y. Thiry, "Les Équations de la Théorie Unitaire de Kaluza"
    110
  • CHAPTER III. NON-ABELIAN GENERALIZATION​
  • B. S. DeWitt, "Dynamical Theory of Groups and Fields", Problem Number 77
    114
  • Ryszard Kerner, "Generalization of the Kaluza-Klein Theory for an Arbitrary Non-Abelian Gauge Group"
    115
  • Y. M. Cho and P. G. O. Freund, "Non-Abelian Gauge Fields as Nambu-Goldstone Fields"
    125
  • E. Cremmer and J. Scherk, "Spontaneous Compactification of Space in an Einstein-Yang-Mills-Higgs Model"
    135
  • J. F. Luciani, "Space-Time Geometry and Symmetry Breaking"
    143
  • Abdus Salam and J. Strathdee, "On Kaluza-Klein Theory"
    163
  • CHAPTER IV. SUPERGRAVITY​
  • E. Cremmer, B. Julia, and J. Scherk, "Supergravity Theory in 11 Dimensions"
    201
  • E. Cremmer and B. Julia, "The N=8N = 8N=8 Supergravity Theory. I. The Lagrangian"
    206
  • P. G. O. Freund and Mark A. Rubin, "Dynamics of Dimensional Reduction"
    210
  • F. Englert, "Spontaneous Compactification of Eleven-Dimensional Supergravity"
    213
  • I. Bars and S. W. MacDowell, "Gravity with Extra Gauge Symmetry"
    217
  • B. Biran, F. Englert, B. de Wit, and H. Nicolai, "Gauged N=8N = 8N=8 Supergravity and Its Breaking from Spontaneous Compactification"
    220
  • A. Casher, F. Englert, H. Nicolai, and M. Rooman, "The Mass Spectrum of Supergravity on the Round Seven-Sphere"
    226
  • M. A. Awada, M. J. Duff, and C. N. Pope, " N=8N = 8N=8 Supergravity Breaks Down to N=1N = 1N=1 "
    242
  • M. J. Duff, B. E. W. Nilsson, and C. N. Pope, "Spontaneous Supersymmetry Breaking by the Squashed Seven-Sphere"
    246
  • R. D’Auria, P. Fre, and P. van Nieuwenhuizen, "Symmetry Breaking in d=11d = 11d=11 Supergravity on the Parallelized Seven-Sphere"
    251
  • Feza Gürsey and Chia-Hsiung Tze, "Octonionic Torsion on S7S^7S7 and Englert’s Compactification of d=11d = 11d=11 Supergravity"
    258
  • G. F. Chapline and N. S. Manton, "Unification of Yang-Mills Theory and Supergravity in Ten Dimensions"
    264
  • D. Z. Freedman, G. W. Gibbons, and P. C. West, "Ten into Four Won’t Go"
    269
  • B. de Wit and H. Nicolai, "A New SO(7)SO(7)SO(7) Invariant Solution of d=11d = 11d=11 Supergravity"
    271
  • CHAPTER V. TOWARDS A REALISTIC KALUZA-KLEIN THEORY​
  • Edward Witten, "Search for a Realistic Kaluza-Klein Theory"
    278
  • CHAPTER VI. COSMOLOGY​
  • Alan Chodos and Steven Detweiler, "Where Has the Fifth Dimension Gone?"
    296
  • Peter G. O. Freund, "Kaluza-Klein Cosmologies"
    300
  • Enrique Alvarez and M. Belen Gavela, "Entropy from Extra Dimensions"
    311
  • Q. Shafi and C. Wetterich, "Cosmology from Higher-Dimensional Gravity"
    315
  • Deshdeep Sahdev, "Towards a Relativistic Kaluza-Klein Cosmology"
    320
  • Edward W. Kolb and Richard Slansky, "Dimensional Reduction in the Early Universe: Where Have the Massive Particles Gone?"
    325
  • Kei-Ichi Maeda, "Is Cosmological Dimensional Reduction Possible?"
    330
  • S. Randjbar-Daemi, Abdus Salam, and J. Strathdee, "On Kaluza-Klein Cosmology"
    335
  • CHAPTER VII. QUANTUM EFFECTS​
  • H. B. G. Casimir, "On the Attraction Between Two Perfectly Conducting Plates"
    342
  • Thomas Appelquist and Alan Chodos, "Quantum Dynamics of Kaluza-Klein Theories"
    345
  • Steven Weinberg, "Charges from Extra Dimensions"
    359
  • Mark A. Rubin and Bernard D. Barkanorth, "Temperature Effects in Five-Dimensional Kaluza-Klein Theory"
    364
  • Philip Candelas and Steven Weinberg, "Calculation of Gauge Couplings and Compact Circumferences from Self-Consistent Dimensional Reduction"
    375
  • N. A. Voronov and Ya I. Kogan, "Spontaneous Compaction in Kaluza-Klein Models and the Casimir Effect"
    420
  • G. W. Gibbons and H. Nicolai, "One-Loop Effects on the Round Seven-Sphere"
    424
  • T. Inami and K. Yamagishi, "Vanishing Quantum Vacuum Energy in Eleven-Dimensional Supergravity on the Round Seven-Sphere"
    431
  • CHAPTER VIII. THE PROBLEM OF CHIRAL FERMIONS​
  • Edward Witten, "Fermion Quantum Numbers in Kaluza-Klein Theory"
    438
  • C. Wetterich, "Dimensional Reduction of Fermions in Generalized Gravity"
    512
  • S. Randjbar-Daemi, Abdus Salam, and J. Strathdee, "Spontaneous Compactification in Six-Dimensional Einstein-Maxwell Theory"
    542
  • Steven Weinberg, "Quasi-Riemannian Theories of Gravitation in More Than Four Dimensions"
    564
  • M. Gell-Mann and B. Zwiebach, "Curling Up Two Spatial Dimensions with SU(1,1)/U(1)SU(1,1)/U(1)SU(1,1)/U(1)"
    569
  • CHAPTER IX. MONOPOLES​
  • Rafael D. Sorkin, "Kaluza-Klein Monopole"
    574
  • David J. Gross and Malcolm J. Perry, "Magnetic Monopoles in Kaluza-Klein Theories"
    578
  • Malcolm J. Perry, "Non-Abelian Kaluza-Klein Monopoles"
    598
  • CHAPTER X. SUPERSTRINGS​
  • M. B. Green and J. H. Schwarz, "Supersymmetrical String Theories"
    604
  • M. B. Green and J. H. Schwarz, "Anomaly Cancellations in Supersymmetric d=10d = 10d=10 Gauge Theory and Superstring Theory"
    608
could you have a viable physics Kaluza-Klein in complex imaginary extra dimensions
honestly I have no idea. Usually C is more simple, symmetry wise, than R. So between C3 and R6... Also, it seems we need seven dimensions but in a very particular way, interpolating between six and eight.
