Modify Phone Battery: Is It Safe?
  • Thread starter Thread starter Stephenk53
    Battery
Modifying a phone by using batteries from stockpiled devices is highly discouraged due to safety concerns. Only batteries of the same model and brand-new condition can be safely paralleled, and even then, consulting the manufacturer is essential. The discussion emphasizes the risks involved, including potential hazards like battery failure or fire. Users are advised to avoid such modifications unless they have confirmed compatibility and safety through reliable sources.
  • Understanding of lithium-ion battery chemistry
  • Knowledge of battery charge/discharge characteristics
  • Experience with soldering and electrical connections
  • Familiarity with manufacturer specifications for batteries
  • Research lithium-ion battery compatibility and safety standards
  • Learn about battery chemistry differences and their implications
  • Explore resources on safe battery modification practices
  • Consult Battery University for in-depth battery knowledge
Individuals interested in phone modifications, electronics enthusiasts, and anyone considering DIY battery replacements or modifications.
Stephenk53
I want to modify my phone by using one of the batteries from phones I have stockpiled over the years and wiring them together. I doubt I have a battery that matches the battery my phone has, so I will have to check. Assuming I have the correct battery, is this a good idea?
By the way I have soldered batteries together before but I want to make sure it's fine since my phone is expensive, at least by my standards
Doesn't sound like a good idea. If you are intending to connect the batteries in parallel, that probably will not work. Only batteries with certain chemistries and very similar charge/discharge histories can be paralleled.
Do you know how I could check if the batteries have a chemistry that work in parallel? As for charge/discharge histories, could I instead get two new batteries or two equally old batteries and use them instead of my current battery. Again assuming the batteries are the same as the one I currently use
I would say the only two batteries that could be successfully paralleled would be if they are the same model and both brand-new. Even then, I would contact the manufacturer to ask if they recommend this.
What could possibly go wrong? Go for it!
http://l7.alamy.com/zooms/de6e99f55...burning-phone-in-jeans-back-pocket-eb1pyd.jpg
Likes sophiecentaur and dlgoff
You may want to go to the Battery University.
Care to tell us some phone types?
Sometime it is possible: but in general, it is futile and dangerous. So without any details, it is a big NO-NO.
Likes sophiecentaur
  • · Replies 32 ·
