Modular arithmetic (casting out 9's)
  • Thread starter Thread starter playa007
    Arithmetic
Rearranging the digits of a positive integer m results in an integer m' such that the difference m - m' is a multiple of 9. This is demonstrated using the casting out 9's method, which shows that both m and m' yield the same remainder when divided by 9. The mathematical representation of m and m' reveals that their difference can be expressed as a combination of powers of 10, each of which is congruent to 1 modulo 9. Consequently, the coefficients of the digits in m and m' lead to a difference that is inherently a multiple of 9. Thus, it is proven that m - m' is divisible by 9.
playa007
Let m be a positive integer and m' be an integer obtained from m by rearranging its digits. Prove that m-m' is a multiple of 9
Casting out 9's method
So I found that by applying the casting out 9's method on m and m'; the values are the same. This means that when one divides m by 9 and m' by 9; it is the same remainder. I'm wondering how do I use this to prove that 9 divides m-m'
Hi playa007! :smile:
erm … m = 9a + r, m' = 9a' + r, so m - m' = … ? :smile:
Also (tiny-tim is exactly right), if a number is written, say m= "abcd"= 1000a+ 100b+ 10c+ d, then, rearranging, m'= "cadb"= 1000c+ 100a+ 10d+ b and m- m'= 1000a+ 100b+ 10c+ d- 1000c- 100a- 10d- b= (1000-100)a+ (100-1)b+ (10-1000)c+ (1- 10)d= 900a+ 99b- 990c- 9d= 9(100a+ 11b- 110c-d), a multiple of 9.
In our "base 10 numeration system", the coefficient of each digit is a power of 10, of course, so no matter how you rearrange the digits, subtracting, the coefficient of each digit is "a power of 10 minus another power of 10" which is always a multiple of 9.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 24 ·
