Modules over an Integral Domain
10 replies · 3K views · last reply
Newtime
Let R be a ring with no zero divisors such that for any [tex]r,s\in R[/tex], there exist [tex]a,b \in R[/tex] such that [tex]ar+bs=0[/tex]. Prove: [tex]R=K \oplus L[/tex] implies [tex]K=0[/tex] or [tex]L=0[/tex].
Definition of direct sum of modules, integral domain...
I didn't know where to start on this one. In particular, I don't see what the hypothesis has to do with anything and certainly I do not see how it's related to the conclusion. I think all I need is a nudge in the right direction.
Assume that [tex]R=K\oplus L[/tex]. Take [tex]k\in K[/tex] and [tex]l\in L[/tex]. Is it ever possible that [tex]ak=bl[/tex] for some [tex]k,l\in R[/tex]??
If this doesn't help you, let's simplify the question: is it possible that k=l?
k=l only if k=l=0 since the sum is direct. Also, it is possible that ak=bl by hypothesis, but I don't see how this points toward a solution.
However, it seems clear that just before we say "thus, l=0" we would use the hypothesis that R is an integral domain and that bl=0.
Ok, you are correct. k=l only if k=0 and l=0.
Can you describe a similar restriction for ak=bl? I.e. what can you say about ak and bl if ak=bl?
Well the obvious implication is that one is the additive inverse of the other: [tex]ak-bl=0[/tex]. But this is just a trivial restatement of what you said so I must be missing something here.
Ok, let's simplify it a bit: can it be true that 2k=l?? (assume for a second that [tex]2\in R[/tex]). Under what conditions can this be true??
Yes but this implies [tex]k,l \in K \cap L=\lbrace 0 \rbrace[/tex] does it not?
micromass said:
Yes, if 2k=l, then k=0 and l=0.
Now, the general case: what if ak=bl??
I still don't see it. The previous case (2k=l) was obvious because 2k stays in K since of course K is a ring and thus closed under addition (2k=k+k). But a and b are arbitrary elements of R so we don't know where the elements ak and bl end up and I don't think the problem is designed to be broken up into cases. Even so, considering the different subcases doesn't seem to help.
Maybe you can prove that K and L are in fact ideals if [tex]R=K\oplus L[/tex]...
So if a is in R, then ak is in K...
I dismissed this idea earlier because I thought it would be more difficult to prove that K and L are ideals than the original claim. But here's what I have :
Let [tex]K \ni k=(k,0)\in K \oplus L, R \ni r=(k_1,l_1) \in K\oplus L[/tex]. Then, [tex]rk = (k_1,l_1)(k,0)=(kk_1,0) = kk_1\in K[/tex]. Thus, K is an ideal.
Assuming this is valid, the problem is complete! Thanks for your help.
