Compare Ions: 1 Mol Nickel (II) vs 1 Mol Copper (I)
  • Thread starter Thread starter NewsboysGurl91
1 mol of Nickel (II) ions results in approximately 1.03 x 1022 ions, while 1 mol of Copper (I) ions yields about 9.48 x 1021 ions. Therefore, Nickel (II) has a greater number of ions compared to Copper (I). The calculations utilize the molar masses of Nickel (58.69 g/mol) and Copper (63.55 g/mol) along with Avogadro's number (6.022 x 1023 ions/mol). Understanding the concept of moles as a counting unit is crucial for these comparisons.
  • Understanding of molar mass (Nickel: 58.69 g/mol, Copper: 63.55 g/mol)
  • Familiarity with Avogadro's number (6.022 x 1023 ions/mol)
  • Basic knowledge of ionic compounds and their properties
  • Concept of moles as a counting unit in chemistry
  • Study the concept of moles in greater detail, focusing on its applications in chemical calculations
  • Learn about the properties and uses of Nickel (II) and Copper (I) ions in various chemical reactions
  • Explore the significance of molar mass in stoichiometry and its impact on chemical equations
  • Investigate the differences between ionic and covalent compounds and their respective behaviors in solutions
Chemistry students, educators, and professionals interested in understanding ionic compounds and their quantitative comparisons.
NewsboysGurl91
Which will have the greater number of ions, 1 mol of nickel (II) or 1 mol of copper (I)?
2. No equations
3. Nickel: 1 mol/58.69 g of Ni * 6.022*10^23 ions/ 1 mol = 1.03 * 10^22 ions.
Copper: 1 mol/ 63.55 g of Cu * 6.022 * 10^23 ions/ 1 mol = 9.48 * 10 ^ 21 ions.
Nickel will have the greater number of ions. Is this correct?
This is like asking "Which bag will have more items, one with a dozen tennis balls or one with a dozen ping pong balls?"
Remember that "moles" is really a number (like dozen is a number) referring to how many of a certain thing.
Think your two calculations should have the units of "ions/gm", not just "ions", after you cancel both "mole" units.
This and chemisttree's info should lead you to the correct answer.
Good luck.
Steve
14K
11K
  • · Replies 16 ·
