How can the molar flow rate of a two-gas mixture be calculated?
The molar flow rate of a two-gas mixture can be accurately calculated by summing the individual molar flow rates of each gas rather than averaging them. For example, if there is 1 mole/min of hydrogen and 1 mole/min of nitrogen, the total molar flow rate is 2 moles/min, not 1 mole/min. The calculation must consider the mass balance and the molar mass of each gas, particularly when dealing with mixtures of different compositions, such as 60% hydrogen and 40% nitrogen. Conservation of mass dictates that the total molar flow is the sum of the individual flows, reinforcing that averaging does not apply in this context.
  • Understanding of molar flow rates
  • Knowledge of mass conservation principles
  • Familiarity with molar mass calculations
  • Basic concepts of gas mixtures and their compositions
  • Study the principles of mass balance in chemical engineering
  • Learn how to calculate molar flow rates for gas mixtures
  • Explore the concept of molar mass and its application in gas calculations
  • Investigate the differences between volumetric and weight-based gas mixtures
Chemical engineers, process engineers, and anyone involved in gas flow calculations and mass balance analysis will benefit from this discussion.
vishnu123
TL;DR
Is there any way to calculate the molar flow rate of the mixture of gaseous?
I have two Gases where i know the molar flow rate of each gas. Is there any way to calculate the molar flow rate of the two gases together or is it just the average of the two molar flow rates?
Chemistry news on Phys.org
Why average?
If there is 1 mole/min of one gas, and 1 mole/min of other gas, average is 1 mole/min also, and it would tell you individual flows are 0.5 mole/min for both gases - yet we assumed there is 1 mole/min. So in some way and for some reason average doesn't work. Can you think why?
thank you for your reply. i think the average won't work because of the percentage flow of each gas.
What about mass balance?
ok, I don't know much about that, can you please explain it in detail.
Basically: mass is conserved (this is one of the most basic principles governing classical physics and chemistry), mass can't disappear, whatever gets in, must get out.
so what you say is it has to be divided by the molar mass of the individual gas?
for example 60%of Hydrogen and 40%of nitrogen to calculate it
(.6*molar flow of H2/molar mass of H2)+(0.4*molar flow of N2/molar mass of N2)
is it right?
You have lost me. Initially you said you know individual molar flows, now you have 40/60 mixture that can be either v/v or w/w. I have never tried to address the other problem.
What mass conservation tells you is that the mixture of 40/60 is 100% in total.
Total molar flow should be the sum of the individual molar flow rates.
AND...conservation of mass and conservation of moles is essentially the same thing unless there is a reaction happening which produces a different number of moles of product vs reactants.
9K
  • · Replies 19 ·
