Moment applied on a circular disc
The discussion focuses on the application of moments on a circular disc, specifically when the moment is applied at the center versus at a point not at the center. When a moment is applied at the center, the disc rotates with an angular acceleration. If the moment is applied off-center, the disc still rotates about the fixed axis at the center, as the moment acts as a free vector. The conversation emphasizes the importance of the fixed rotation axis, which dictates the rotational behavior of the disc regardless of the point of moment application.
  • Understanding of angular acceleration and its calculation
  • Knowledge of fixed and free vectors in physics
  • Familiarity with rotational dynamics and moments
  • Concept of fixed rotation axes in rigid body motion
  • Study the principles of rotational dynamics and angular momentum
  • Learn about the effects of applying forces at different points on rigid bodies
  • Explore the concept of couple moments and their impact on rotation
  • Investigate the differences between fixed and movable axes in rotational systems
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of rotational motion in rigid bodies.
chandran
moment on a circular disc(moment applied in the centre)
A circular disc is hinged in the centre. I am applying a moment at the centre. The result is that the disc will rotate with an angular acceleration "a"
moment on a circular disc(moment applied not in the centre)
A circular disc is hinged in the centre. I am applying a moment at some point in the disc but not at the centre. How can i calculate the angular frequency. What is the theory? Will the disc rotate?
For your moment not applied at the center, it will still rotate about the center. The moment is a free vector, it can act anywhere you put it. It will cuase rotation around the fixed point of the body, if that point allows for rotation in the direction of the moment.
EDIT: What I said applies for a couple moment, if that's what you mean.
i am not getting. pls elaborate.
Because one is incorporating a fixed rotation axis for the disk, it does not matter where on the disk other than its axix that you apply a tangental force to initiate rotation about that axis.
This would NOT occur if there were no fixed axis. In that case, the disk would rotate around its center of mass, which can be substantially different that the location of a fixed axis.
With a "fixed axis", centered or not, you are "forcing" rotation to occur around that axis.
  • · Replies 41 ·
  • · Replies 43 ·
