Moment of Inertia - equilateral triangle
The forum discussion focuses on calculating the moment of inertia for an equilateral triangle through point A. The initial attempt used the equation I = ∫r²dm, leading to an incorrect result of I = (2/3)ML². The correct integration limits were identified as necessary for accurate calculations, with participants arriving at the correct moment of inertia of I = (5/12)ML² after adjusting their approach. The integration involved using double integrals and applying the Pythagorean theorem to derive r² as x² + y².
  • Understanding of double integrals in calculus
  • Familiarity with the concept of moment of inertia
  • Knowledge of the Pythagorean theorem
  • Basic principles of mass distribution in physics
  • Study the derivation of moment of inertia for various geometric shapes
  • Learn advanced techniques for double integrals in multivariable calculus
  • Explore applications of moment of inertia in engineering and physics
  • Investigate the relationship between mass distribution and moment of inertia
Students studying physics, particularly those focusing on mechanics, as well as educators and professionals involved in engineering and applied mathematics.
zwingtip
[PLAIN]http://img59.imageshack.us/img59/9484/fp5.gif
to find the moment of inertia through point A
I = \int{r^2dm}
Used a double integral from point A:
<br /> \displaystyle\int_{0}^{h}\displaystyle\int_{-L/2}^{L/2}\rho(x^2+y^2)dxdy<br /> = \rho\displaystyle\int_{0}^{h}\(\frac{1}{12}L^3+Ly^2)dy = \rho(\frac{1}{12}L^3h+\frac{1}{3}Lh^3)<br />
with
h=\frac{\sqrt{3}}{2}L
and
\rho=\frac{M}{\frac{1}{2}Lh}
and ended up with I = \frac{2}{3}ML^2
This seems too simple to be right. Help?
It is not correct. The integration with respect to x has to go from the left side of the triangle to the right side.
ehild
Okay, in that case, I have no idea how to integrate it. Help? I tried integrating it as a function of y and got
\frac{3\sqrt{3}}{16}ML^2
But that doesn't seem right either.
<br /> <br /> \displaystyle\int_{0}^{h}\displaystyle\int_{-y/\sqrt 3}^{y/\sqrt 3}\rho(x^2+y^2)dxdy<br /> <br />
ehild
Thanks. I'll try it.
Is the answer
\frac{5}{12}ML^2
Hi,
Can anyone explain how x^2 + y^2 was obtained. I understand how to do double integral, but i am not adapt at applying it.
Delzac
In the moment of inertia, x^2+y^2 is r^2 (pythagorean theorem)
zwingtip said:
Is the answer
\frac{5}{12}ML^2
I got the same result.
ehild
26K
