Moment of inertia for a door help
The moment of inertia for a 19kg door, measuring 2.5m in height and 1.1m in width, hinged along its long side, can be calculated using the integral formula I = ∫(R² dm). To solve this, the door should be conceptualized as composed of thin vertical slices, where each slice's mass (dm) is determined based on its distance (R) from the hinge. This approach allows for the application of calculus to derive the moment of inertia analytically.
  • Understanding of moment of inertia concepts
  • Familiarity with calculus, specifically integration
  • Knowledge of mass distribution in rigid bodies
  • Basic principles of physics related to rotational motion
  • Study the derivation of moment of inertia for rectangular objects
  • Learn about the application of integrals in physics
  • Explore examples of calculating moment of inertia for various shapes
  • Review the principles of rotational dynamics and their equations
Students in physics or engineering courses, particularly those studying mechanics, as well as educators seeking to explain the concept of moment of inertia for non-cylindrical objects.
ahello888a
Determine the moment of inertia of a 19kg door that is 2.5m high and 1.1m wide and is hinged along long side. Ignore the thickness of the door
I=\int (R^2 dm)
I really don't know where to start with this problem. My book only shows me how to do moments for cylindrically shaped objects and rods, so i don't know how to deal with 2d objects. I'm having particular trouble with coming up with a dm that is reliant on R.
The general definition of moment of intertia is to consider a small part of the object with mass dm at a distance r and sum the product of r*r dm.
So for the door, imagine splitting the door into thin vertical slices, then calculate the mass of the slice and the square of the distance from the hinge.
If you know calculus you can do this analytically and come up with an equation - that's what the integral you have given calculates
i still have absolutely no clue how to do this. can you point to an example or something?
never mind...
  • · Replies 16 ·
  • · Replies 21 ·
