Moment of Inertia for Ellipsoid
The discussion focuses on calculating the moment of inertia for an ellipsoid defined by the equation x²/a² + y²/b² + z²/c² = 1. The volume integral ∫∫∫E dV was correctly evaluated as 4/3πabc using the transformation x=au, y=bv, z=cw. However, the initial assumption that the moment of inertia about the z-axis would be zero was incorrect. The correct approach involves using the moment arm r² = x² + y² instead of the previously used x²y, which led to the misunderstanding.
  • Understanding of triple integrals and volume calculations
  • Familiarity with the concept of moment of inertia
  • Knowledge of coordinate transformations in multivariable calculus
  • Basic understanding of Jacobians in integration
  • Study the derivation of moment of inertia for various geometric shapes
  • Learn about Jacobians and their applications in coordinate transformations
  • Explore advanced integration techniques in multivariable calculus
  • Investigate the physical significance of moment arms in rotational dynamics
Students in physics and engineering, particularly those studying mechanics and multivariable calculus, will benefit from this discussion on the moment of inertia for ellipsoids.
ledphones
a)Evaluate ∫∫∫E dV, where E is the solid enclosed by the ellipsoid x^2/a^2+y^2/b^2+z^2/c^2 =1. Use the transformation x=au, y=bv, z=cw.
b)If the solid in the above has density k find the moment of inertia about the z-axis.
∅=phi
I got a correct 4/3∏abc
i thought b) would be 0 based on the following.
Jacobian is abc and the solid enclosed would be u^2+v^2+w^2≤1
x^2*y=(a^2*u^2)(bv)
V=∫∫∫(a^2bu^2v)(abc)dudvdw
=∫0→2∏ ∫0→∏ ∫0→1 (a^3b^2c)(ρ^2sin^2∅cos^2θ)(ρsin∅sinθ)ρ^2sin∅dρd∅dθ
=a^3b^2c∫∫∫(ρ^5sin^4∅cos^2θsinθ)dρd∅dθ
=a^3b^2c∫0→2∏ cos^2θsinθdθ∫0→∏ sin^4∅d∅ ∫0→1 ρ^5dρ
=0 since the 1st integral is 0
∅=phi
x^2*y=(a^2*u^2)(bv)
The integrand for a second moment is always positive. Your problem is in the last step above. The moment arm is the distance squared from the z axis: r2=x2+y2, not x2y.
  • · Replies 47 ·
