Momentum and net external force
7 replies · 4K views
Joe Armas
In the picture
In the picture attached.
For the firecracker problem, I believe the only net external force is gravity. Therefore using, Fnet * delta t = delta p. Change in momentum is 12 kg * m/s. Thus, the final momentum of the system is zero. Is this reasoning correct? Please let me know of any errors in my reasoning. Thank you.
Right.
How did you conclude that?
Nathanael said:
Right.How did you conclude that?
The initial momentum of the system is 3kg * -4m/s = -12 kg * m/s. The change in momentum from gravity is 12 as I explained.
Pf = Pi + Delta P
Pf = -12 + 12 = 0
Pf = Pi + Delta P
Pf = -12 + 12 = 0
By saying "-4 m/s" you have defined a direction for positive and negative.
The magnitude of the change in momentum is 12 kg.m/s, but Δp is a vector; what is it's direction?
Gravity then should be negative since it too acts downward. So, delta p should be -30 * 0.4 or -12? So final momentum of system is actually -24 kg * m/s. The bottom piece of mass 2kg must therefore be moving at -14 m/s, since the top piece of mass 1kg is moving at +4m/s, and the sum of these two final momenta must add up to -24 kg * m/s.
Nathanael said:
Yes, it is correct.
I know in part b there is a net external force (gravity) that does positive work, fnet > 0, thus dp/dt is positive. Does the spring in part c increase or decrease the momentum of the system? I am not too sure of my answer.
