Momentum and net external force
7 replies · 4K views · last reply
Joe Armas
In the picture
In the picture attached.
Textbook page on conservation of momentum showing a firecracker explosion problem with before and after diagrams, handwritten work and a vector diagram grid, with parts a through f.
For the firecracker problem, I believe the only net external force is gravity. Therefore using, Fnet * delta t = delta p. Change in momentum is 12 kg * m/s. Thus, the final momentum of the system is zero. Is this reasoning correct? Please let me know of any errors in my reasoning. Thank you.
  • Handwritten worked solution on a printed Mech HW-65 sheet about momentum in one dimension, with three glider collision diagrams and handwritten net force and momentum reasoning.
Right.
How did you conclude that?
Nathanael said:
Right.How did you conclude that?
The initial momentum of the system is 3kg * -4m/s = -12 kg * m/s. The change in momentum from gravity is 12 as I explained.
Pf = Pi + Delta P
Pf = -12 + 12 = 0
Pf = Pi + Delta P
Pf = -12 + 12 = 0
By saying "-4 m/s" you have defined a direction for positive and negative.
The magnitude of the change in momentum is 12 kg.m/s, but Δp is a vector; what is it's direction?
Gravity then should be negative since it too acts downward. So, delta p should be -30 * 0.4 or -12? So final momentum of system is actually -24 kg * m/s. The bottom piece of mass 2kg must therefore be moving at -14 m/s, since the top piece of mass 1kg is moving at +4m/s, and the sum of these two final momenta must add up to -24 kg * m/s.
Nathanael said:
Yes, it is correct.
Photo of a handwritten physics worksheet page held in a hand, showing printed problem parts a, b and c about momentum, with three small diagrams of a cart on a ramp or track to the right and handwritten annotations below.
I know in part b there is a net external force (gravity) that does positive work, fnet > 0, thus dp/dt is positive. Does the spring in part c increase or decrease the momentum of the system? I am not too sure of my answer.
