Momentum cut-off regularisation & Lorentz invariance
5 replies · 2K views
Frank Castle
Why is it that introducing a hard cut-off ##p^{2}=\Lambda^{2}## breaks Lorentz invariance? Is it simply that it introduces an energy scale and energy is not a Lorentz invariant quantity?
Sorry if this is a trivial question, but I just want to make sure I understand the reasoning as I've heard/read it being stated, but never fully appreciated why.
Well, if the cut-off is defined by
$$p^{2}=\Lambda^{2}. . . . . (Eq. 1)$$
then it does not break Lorentz invariance, because
$$p^{2}=p_0^2-{\bf p}^2. . . . . (Eq. 2)$$
is Lorentz invariant. However such a cutoff does not really make physical quantities finite because, with finite positive ##\Lambda^{2}##, (Eq. 1) allows ##p_0## and ##|{\bf p}|## to be arbitrarily big. To bound ##p_0## and ##|{\bf p}|## one can replace (Eq. 2) with a Euclidean scalar product
$$p^{2}_E=p_0^2+{\bf p}^2. . . . . (Eq. 3)$$
but then it is no longer Lorentz invariant.
Demystifier said:
To bound p0p_0 and |p||{\bf p}| one can replace (Eq. 2) with a Euclidean scalar product
p2E=p20+p2...(Eq.3)​
Is it instead "Euclidean" invariant? Is it possible to show that the cut-off can't also be Lorentz invariant? Is there any physical intuition as to why a cut-off breaks Lorentz invariance?
Yes.
I think I have just shown that.
Sure. Suppose that there is some maximal possible energy-momentum ##p^{\mu}##, and suppose that it is a time-like vector. Then there is a Lorentz frame in which
$$p^{\mu}=(\Lambda,0,0,0)$$
But if ##p^{\mu}## has this form in one Lorentz frame, then it cannot have this form in other Lorentz frames. Therefore there is a special Lorentz frame in which ##p^{\mu}## takes this special form. But if there is a special Lorentz frame, then there is no Lorentz invariance.
I guessing because if it is "Euclidean" invariant then it cannot be simultaneously Lorentz invariant?!
Demystifier said:
Sure. Suppose that there is some maximal possible energy-momentum pμp^{\mu}, and suppose that it is a time-like vector. Then there is a Lorentz frame in which
pμ=(Λ,0,0,0)​
But if pμp^{\mu} has this form in one Lorentz frame, then it cannot have this form in other Lorentz frames. Therefore there is a special Lorentz frame in which pμp^{\mu} takes this special form. But if there is a special Lorentz frame, then there is no Lorentz invariance.
So would it be correct to say that a hard cut-off introduces an energy scale, which is not Lorentz invariant (since energy is not a Lorentz invariant quantity)?
Yes.
It wouldn't be wrong.
