Monatomic Ideal Gas volume expansion
9 replies · 20K views · last reply
TFM
[SOLVED] Monatomic Ideal Gas volume expansion
A monatomic ideal gas expands slowly to twice its original volume, doing 260 Joules of work in the process.
(a)
Find the heat added to the gas if the process is isobaric.
(b)
Find the change in internal energy of the gas if the process is isobaric.
[tex]U = \frac{1}{2}nRT[/tex] per degree of freedom
pV = nRT
pV = const.
p/T = Constant
V/T = const.
I am not quite sure what to do for this equation. I now that the pressure is constant, and the the volue has doubled. and it has done 260 Joul;es of work in the process.
Any ideas where to start?
TFM
Try to figure out the change in internal energy. You'll have to play around a bit. Assemble all the equations that apply to this problem and see what you can do.
Have I started this the right way.
The gas is monatomic, so
[tex]U = \frac{3}{2} nRT[/tex]
R is a constant, 8.31
[tex]U = \frac{3}{2} 8.31*nT[/tex]
However, we don't know thenumber of moles.
[tex]\frac{v_1}{T_1} = \frac{v_2}{T_2}[/tex]
We know the volume of v2 is twice that of V1
[tex]\frac{1}{T_1} = \frac{2}{T_2}[/tex]
This gives the ratio of temperatures as:
[tex]\frac{T_1}{T_2} = \frac{1}{2}[/tex]
Does this look right so far? If so, what could be a possible next step?
TFM
Good.
Combine this with the ideal gas law and an expression for the work done.
Don't plug in numbers until the last step.
Following on then,
[tex]pV = nRT[/tex]
[tex]n = \frac{pV}{RT}[/tex]
Insert into U ewquation,
[tex]U = \frac{3}{2} \frac{pV}{RT} RT[/tex]
Cancels to:
[tex]U = \frac{3}{2} pV[/tex]
The Work Equation:
[tex]W = p \Delta V[/tex]
thus,
[tex]p = \frac{W}{\Delta V}[/tex]
putting into the equation gives:
[tex]U = \frac{3}{2} \frac{W}{\Delta V}V[/tex]
Sincve the V is changing anyway:
tex] U = \frac{3}{2} W [/tex]
and we have the work.
Does this look right?
TFM
Sorry, that final equation hould have been:
[tex]U = \frac{3}{2} W[/tex][/B]
Is this correct?
TFM
I assume you mean:
Is this correct?
Good! Now use it to find the heat added.
Would you use:
[tex]\Delta U = Q - W[/tex]
[tex]\Q = U + W[/tex]
TFM
I put the values ion and the right answer did come out!
Thanks for your assistance, Doc Al, :smile:
TFM
