More reduction of order DiffEq goodness
  • Thread starter Thread starter bitrex
    Diffeq Reduction
The discussion revolves around solving a differential equation using the substitution \( y = (x^2 + 1)u \). The original poster attempts to simplify the equation and reduce its order, leading to a separable differential equation.
  • Participants discuss the substitution and simplification process, with one participant noting an error in the integration step involving trigonometric identities. There is also a focus on the implications of constants in the integration process.
Some participants are providing feedback on the original poster's calculations, particularly regarding the integration of trigonometric functions and the handling of constants. There is an ongoing exploration of the implications of these errors on the overall solution.
Participants are working under the constraints of a homework assignment, which may limit the depth of discussion regarding the solution methods. There is an acknowledgment of potential errors in the calculations that could affect the final result.
bitrex
Use the substitution [tex]y = (x^2 + 1)u[/tex] to solve the differential equation [tex](x^2 +1)y\prime\prime = 2y[/tex]
I was having some trouble with these earlier because I needed to brush up on my trigonometric substitution. Let's try this one...
Making the substitution and simplifying the resultant equation gives us the differential equation [tex](x^2 + 1)u\prime\prime + 4xu\prime = 0[/tex]. Reducing the order then by substituting [tex]p = u\prime[/tex] [tex]p\prime = u\prime\prime[/tex] gives us the separable Deq [tex](x^2 +1)\frac{dp}{dx} + 4xp = 0[/tex].
So
[tex]\frac{1}{p}dp = \frac{-4x}{x^2 +1} dx[/tex]
[tex]ln|p| = -2 ln|x^2 + 1| + C_1[/tex]
[tex]p = C_1\frac{1}{(x^2 +1)^2}[/tex]
substitute [tex]x = tan \theta[/tex] to integrate the above equation to get U
[tex]u = C_1\int\frac{ sec^2\theta}{(1+tan^2\theta)^2}d\theta = C_1\int\frac{1}{sec^2\theta}d\theta =[/tex]
[tex]C_1\int cos^2\theta d\theta[/tex]
[tex]C_1\int \frac{1}{2} + \frac{cos2\theta}{2}d\theta = C_1(\frac{\theta}{2} + sin\theta cos\theta + C_2)[/tex]
substituting back x for theta we get:
[tex]u = C_1( \frac{tan^{-1} x}{2} + \frac{x}{x^2 +1} + C_2)[/tex]
and substituting u into the first substitution:
[tex]y = (x^2 +1)(C_1( \frac{tan^{-1} x}{2} + \frac{x}{x^2 +1}) + C_2).[/tex]Hopefully I've made fewer errors this time around! :wink:
[tex]\cos^2\theta\neq\frac{1}{2}[1+\sin(2\theta)][/tex]
I don't see where I made that substitution? I now see I did make an error on this line:[tex]C_1\int \frac{1}{2} + \frac{cos2\theta}{2}d\theta = C_1(\frac{\theta}{2} + sin\theta cos\theta + C_2)[/tex]
The integral of [tex]\frac{cos(2\theta)}{2} = \frac{sin(2\theta)}{4}[/tex], which I then replaced with a trigonometric identity should end up as [tex]\frac{sin(\theta)cos(\theta)}{2}[/tex]...fortunately in this case I don't think the damage is too great as the factor of 1/2 should be swallowed by the constant!
The factor of 1/2 isn't swallowed by the constant since the same constant multiplies another term. Fix the rest of your calculation with the 1/2 and you should be fine.
  • · Replies 19 ·
  • · Replies 22 ·
