MOSFET Design Doubt: Explaining Positive Voltage
4 replies · 2K views
shawrix
Can someone explain this sentence in MOSFET design..
The Since the drain will be at a positive voltage relative to the source the two pn junctions can be effectively cut off simply connecting the substrate terminal to source terminal.
As far as I know the substrate and source are usually connected, and does not cut off the transistor in any way.
Since the drain is stated to be more + than the source, the device is an NMOS unless the device is operated in the inverse mode, which is almost never the case.
As stated in a previous post, the souce & substrate are usually but not always connected. That connection does not cut off the device.
... with the substrate connected to the source, the two back-to-back pn junctions cause the drain-source path to be a non-conducting path. Under these conditions (with the absence of gate voltage) the enhancement-mode MOSFET is in cut-off.
