Motion in circles mechanical engineering
2 replies · 2K views
study12
first time guys.
i have a disc with a bearing and a shaft through it. the disc is rotating in simple harmonic motion with a dynamic force of 14400N and speed of 2.43 rpm. i need to use electromagnets to stop this disc from rotating.
questions.
-where or can can i get electromagnets to stop 14400N . the max i have found is just 1000N
- what calculations do i need to consider in calculating magnetic field resistance.
What do you mean when you say that the disk is rotating with SHM? Is it rotating, or is it translating side to side? Is the 14400 N an oscillating force, or is it steady?Can you provide a sketch of the situation? This would probably help a lot. Please specify the materials for the parts also.
what is providing that 14400 N of force (I'm assuming that is centripetal force?)
If you stop that source, the disk will eventually stop due to friction with the bearings, and the air.
Applying an extra 1000 N of force will assist with that deceleration.
can you chain the magnets together? have one magnet on one side, and another magnet on the other side?
