How Does Projectile Motion Affect a Soccer Ball's Velocity After 0.50 Seconds?
  • Thread starter Thread starter hatcheezy
    Motion
hatcheezy
A soccer ball is kicked so it follows the path of a projectile. It is given an initial velocity of 7.5 m/s at an angle of 25 degrees to the horizontal as it leavest he ground. What is the velocity of the ball 0.50 seconds after the ball leaves the ground?
V=Vo + (a)(t)
no clue
Find the horizontal and vertical components of velocity. Horizontal velocity remains constant. Find the vertical velocity after time t using the relevant equation given by you. Finally find the resultant velocity by using vector method.
  • · Replies 38 ·
  • · Replies 22 ·
