monty37
- 225
- 1
can the motion of a piston be considered simple harmonic,being periodic in nature?in*case of a reciprocating engine.
The motion of a piston in a reciprocating engine cannot be classified as simple harmonic motion (SHM) due to its non-sinusoidal nature and finite dwell time at top dead center (TDC). The discussion highlights that while periodic, the piston does not exhibit the characteristics of SHM unless the connecting rod is infinitely long, which is a theoretical scenario. The relationship between crankshaft rotation and piston movement is described through a crank-slider mechanism, emphasizing the importance of rod length and crank throw ratio in determining piston dynamics. The equation for piston position versus crank angle is provided, illustrating the complexities of piston motion in real-world applications.
PREREQUISITESEngineers, mechanical designers, automotive enthusiasts, and students studying mechanical motion and engine dynamics will benefit from this discussion.
monty37 said:but simple harmonic motion does not necessarily mean sinusoidal,the piston for every stroke moves up and down ,this is a continuous process,why should it not be SHM? please explain the infinitely long connecting rod as well.
Ranger Mike said:the piston has a finite dwell time ( in crankshaft degrees) at top dead center as verified with a degree wheel when properly installing a cam shaft..in other words , the piston " stops moving" for a short period of time ( number of crankshaft degrees) while at TDC
