Motion on a ring. Quantum mechanics.
7 replies · 1K views
LagrangeEuler
Particle of mass [tex[m[/tex] is confined on the ring of constant radius [tex]r_0[/tex]. Solve Schroedinger equation for this problem.
Problem is solved here
http://www.physics.oregonstate.edu/~corinne/COURSES/ph426/notes3.pdf
Why Schroedinger equation is written in the form
[tex]\frac{d^2\Phi}{d\varphi}=-\frac{2I}{\hbar^2}[E-U(r_0)]\Phi(\varphi)[/tex]
I am confused. First of all why moment of inertia [tex]I[/tex]? Second how potential [tex]U(r_0)[/tex] is defined? Is it [tex]\infty[/tex] everywhere accept at [tex]r_0[/tex]? Thanks for the answer.
If you write ##\varphi## as function of x (or vice versa) and substitute it in the Schrödinger equation, you get a factor of ##mr_0^2## in the equation, which is ##I##.
As your Schrödinger equation depends on the angle only, everything outside the ring "does not exist" in the world of this particle. If your potential depends on the radius only, it is constant for a particle at a specific radius.
Thank you for the answer. How you mean write as function of [tex]x[/tex]? What is [tex]x[/tex] for you in this problem.
I am not sure why particle moves around the ring? When I say particle is moving around the ring then I can right equation where wave function is only function of angle [tex]\varphi[/tex]. But first at all why particle is moving around the ring. Is it because of potential?
x is a linear distance. The position variable you usually see in the Schrödinger equation.
It does not have to move, but it has to be on the ring due to some unexplained and irrelevant external world. The usual reason would be a potential, yes.
Thank you. If x is linear distance then Schroedinger equation takes a form
[tex]\frac{d^2 \psi}{dx^2}=-\frac{2m}{\hbar^2}[E-U)\psi(x)[/tex]
I am not sure how to go from this equation to
[tex]\frac{d^2 \Phi}{d \varphi^2}=-\frac{2I}{\hbar^2}[E-U)\Phi(\varphi)[/tex]
The first equation has a typo.
How are linear distance (along the ring) and the angle phi related? The rest is using the chain rule on the left side.
Thank you. ##x=r_0\varphi##
So because ##r_0## is constant
[tex]\frac{d^2\psi}{dx^2}=\frac{1}{r^2_0}\frac{d^2\psi}{d\varphi^2}[/tex]
