Motion under influence of a resistive force
The discussion focuses on the motion of a body influenced by a resistive force defined by F = -m*γ*vα, where m is mass, γ is a constant, v is velocity, and α is a dimensionless constant. The equation of motion v'' = -γ*vα leads to the time equation t = (1/γ)*(V0^(1-α))/(1-α), indicating that for γ > 1, the time to stop is finite. However, the sign of t becomes negative for certain values of α, particularly when α = 2, which raises questions about the physical realism of such scenarios. The discussion concludes that while t is positive for α = 0, it becomes non-physical for α values greater than 1.
  • Understanding of classical mechanics and Newton's laws of motion
  • Familiarity with differential equations and their applications in physics
  • Knowledge of resistive forces and their mathematical representation
  • Basic grasp of dimensional analysis and physical realism in mathematical models
  • Explore the implications of different values of α on motion dynamics
  • Study the behavior of resistive forces in various physical contexts
  • Investigate the solutions to differential equations in classical mechanics
  • Analyze the concept of physical realism in mathematical modeling
Students and professionals in physics, particularly those studying dynamics and resistive forces, as well as researchers interested in mathematical modeling of motion under various forces.
Ananthan9470
No template because originally posted in wrong thread
Consider the 1d motion of a body under the influence of the force given by F = -m*γ*vα. m is mass, γ is a constant of appropriate dimension, v is velocity and α is dimensionless constant. The value of α for which the motion will come to a stop in finite time is to be calculated. I solved the equation of motion given by v'' = -γ*vα and got an equation for t given by t = (1/γ)*(V01-α)/(1-α); V0 is the initial velocity. According to this, for all γ>1, time is finite. But the sign of t is negative. Why is this happening? Am I doing something wrong?
Your solution for t is correct. What do you get for t if ##\alpha = 0##? Is this a finite time? Is it positive?
For ##\alpha = 0## it is positive but what about something like α = 2? It is turning out to be negative unless I am mistaken. right?
Yes. That's the region that is not physically realistic.
What do you get when ##\alpha = -1##? Is that a finite time? What do you get for v vs t in the special case when ##\alpha = 1##?
  • · Replies 39 ·
  • · Replies 25 ·
