Motion w/ Constant Acceleration
The discussion revolves around a problem involving constant acceleration, specifically related to a jet plane's change in speed over a certain distance. The original poster presents the scenario where a jet accelerates from 300 m/s to 400 m/s over a distance of 4.0 km and seeks to determine the acceleration.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the need for time (delta-t) to calculate acceleration, noting that both acceleration and time are unknowns. There are suggestions to recall formulas that relate initial and final velocities with displacement.
Some participants provide guidance on using known equations of motion, while others express confusion about how to apply these equations without additional information. There is an ongoing exploration of different approaches, with no clear consensus on the best method to proceed.
The original poster expresses frustration with the learning environment, indicating that the course material is ahead of their current understanding, which may impact their ability to engage with the problem effectively.
lawsonj
"A jet plane is cruising at 300 m/s when suddenly the pilot turns the engines up to full throttle. After traveling 4.0 km, the jet is moving with a speed of 400 m/s."
"What is the jet's acceleration, assuming it to be a constant acceleration?"
The way I see it, the only info we have is v-initial = 300 m/s , v-final = 400 m/s , and delta-x = 4000 m.
To find acceleration I would need delta-t. All the equations that I'm cognizant of seem to include both acceleration and delta-t, both variables that are not given. It seems like I would need the acceleration to find delta-t. I also seems I would need delta-t to find acceleration.
This seems like a simple problem, but I don't even know how to approach it. So far this semester I've been teaching myself, because our homework and quizzes are at least 1 chapter ahead of our lectures, which means our prof. isn't teaching us jack sh!t, just (inadequately) reviewing material that we've already taught ourselves to do the homework and quizzes. This class is really making me hate physics, which I formerly loved and wanted to major in. :(
What should my methodology be from the get-go?
Are you sure that you haven't learned a formula involving vi, vf, and displacement? If you don't recall such, look over the chapter in your textbook.
Alternatively, you could involve displacement by using an equation you already know which does involve displacement, though via this route you'll need to solve a pair of simultaneous equations.
Then you need to find some different equations.
Do a little research on the web if your textbook is inadequate.
Here is a list of various equations of motion:
https://sentynel.com/media/old/equations.html
well yes, there is [s-final = s-initial = v*delta-t] , but there is delta-t, and only one term for v. I tried using this equation, but to solve for delta-t, I would only be using one term of velocity, what value would I use?
There is also [s-final = s-initial + v-initial*delta-t + (1/2)a(delta-t)^2], but once again, there is delta-t AND a, which are unknown, and only one value of v.
My assumption is that I need to find delta-t to do anything here...but I don't know how to incorporate a difference of velocities into an equation requiring only 1 velocity term.
Solving two equations simultaneously means you can start out with two unknowns. You then end up determining the values of either of those unknowns, or both if need be, by following the method you learned in maths for solving simultaneous equations.
I'm not sure what you're alluding to here, it's a little vague...My algebra isn't very good, so I'm not sure what method you're referring to that will let me solve for the variables I need without needing more information than I have.
You've got the right equations here, but let's re-write them into a form which is more easily readable:
The first equation:
vf = vi + at
and the second:
sf = si + vit + (1/2)at2
If you look at the first equation, you can still solve for t even if a remains unknown for the moment.
The second equation can be simplified a bit by taking si = 0. You should be able to substitute t from solving the first equation into the second to find a.
You have sufficient information to solve this problem.
You apparently didn't bother to search the list of motion equations which was linked to, but the one you need can be derived as described above.
A suggestion: If you plan on studying physics to any degree, you need to get better at algebra (and more). If your math is dodgy, then this will keep you from solving even the simplest problems (like this one), let alone more complex problems.
The first equation:
vf = vi + at
and the second:
How can you solve for t without a? by substituting the values for vel., I get [100 m/s = at] or [(100/t) = a]. Either way I can't solve t or a.
I did look at the list of equations. The one you described above is one I was already using.
Is it forum rules to not answer homework questions? So far all the help I've gotten comes in the form of more questions that don't help explain what I've actually done wrong. No one has mentioned how my thinking is incorrect, or pointed out where in my assumptions/methods I've gone wrong. Without knowing what I've done wrong, I'm no closer to advancing any skills. "You have sufficient information to solve this" isn't really advice...Its what a robot says to a human when the human asks for help.
You can find an expression for t without knowing the value of a from the first equation. You substitute this expression for t into the second equation, which then you can solve for a in terms of the distance and the initial and final velocities.
You didn't look far enough down the list I posted.
There is an equation from which acceleration can be calculated knowing only a distance and an initial and final velocity.
Yes, yes it is. HW helpers are allowed to provide hints and to point out errors in calculation or reasoning, but providing direct solutions is not permitted.
No one has said you've done anything wrong. You have not, however, put forth any effort at solving your own equations to find the acceleration, even after additional hints were provided to you. Whether this is due to a lack of algebra skills, or some other reason altogether, is not clear.
If you are dissatisfied with the help you have received, you are entitled to a full refund. :wink:
lawsonj said:
You are nothing but completely unaware of what work I am doing. What I post on this forum is not indicative of how much work I have done outside the forum.
nothing like sarcasm to make me feel welcome...sheesh
You started to solve equation 1 for a and then stopped. Why? You didn't even try to substitute your expression for a into equation 2.
You've shown two equations involving a and t, both of which are unknown. You can't find either a or t without working with both equations. This is precisely where lack of knowledge of algebra, and solving simultaneous equations in particular, is holding you back from learning physics.
  • · Replies 33 ·
