Motion with constatnt acceleration problem
The problem involves two motors, a rocket and a jet, tested on a horizontal track. The rocket accelerates constantly for half the distance and then moves at a constant speed, while the jet motor accelerates constantly for the entire distance. Both motors are said to cover the same distance in the same time, and the goal is to determine the ratio of their accelerations.
  • Exploratory, Assumption checking
  • Participants discuss the equations governing the motion of both motors and attempt to derive the ratio of their accelerations. Some participants express confusion over the conditions of the rocket's motion, particularly regarding whether it runs out of fuel or maintains constant speed for the second half of the track.
There is an ongoing exploration of the problem with various interpretations of the rocket's motion. One participant has received clarification that helped them progress, while others continue to question their initial assumptions and calculations. Guidance has been provided in the form of equations and suggestions for structuring the problem.
Participants note the importance of accurately defining the motion of the rocket motor, particularly regarding its acceleration and the conditions under which it operates. There is also mention of the forum's LaTeX compatibility, which may assist in presenting mathematical expressions more clearly.
Stochastic13
On a horizontal test track two motors (jet and rocket) are tested. Starting from rest, the rocket motor was accelerated constantly for half the distance of the track and ran the other half at a constant speed. Next, a jet motor was started from rest and finished the whole track with constant acceleration for the entire distance. Both motors covered the same distance in the same time. Show that the ratio of the acceleration of the jet motor to rocket motor is given by: aj/ar = 8/9
x = xo + volt + 1/2 at^2 where xo and vo are initial distance and velocity respectively
I wrote two equations for the distance of each motor. For rocket: x = 1/8 ar*t^2 + v*t/2 and since v*t/2 = ar*t^2/4 we get x = 1/8 ar*t^2 + v*t^2/4 and for the jet motor: x = 1/2 aj*t^2 and set them equal to each-other and find that the ratio is aj/ar = 3/4 instead of 8/9. What am I doing wrong?
I just got an answer from popovoleg that makes a lot of sense, that acceleration remains constant. In my original question I said that the other half the distance is traveled at a constant speed; I should have said that the rocket runs out of fuel at half the distance for the rocket motor. But I then get (1/2) aj * t^2 = (1/2) ar (t/2)^2 and the final answer comes out aj / ar = 1/4 which is not 8/9 so I'm still making a mistake somewhere.
Hi.
You get the right answer following your problem statement. So wheter the rocket motor runs out of fuel or whatever the case. Saying it runs the last half of the track at constant speed is probably right.
You have to put the words into equations like this:
(1) "Starting from rest, the rocket motor was accelerated constantly for half the distance of the track..."
\frac{R_T}{2} = x_{or} + v_{or} t_{r1} + \frac{a_r t_{r1}^2}{2} = \frac{a_r t_{r1}^2}{2}
(2) " ...(The rocket motor) ran the other half at a constant speed."
\frac{R_T}{2} = v_{fr} t_{r2} = (a_r t_{r1}) t_{r2}
(3) "Next, a jet motor was started from rest and finished the whole track with constant acceleration for the entire distance."
R_T = x_{o j} + v_{oj} t_j + \frac{a_j t_j^2}{2} = \frac{a_j t_j^2}{2}
(4) "Both motors covered the same distance in the same time."
t_j = t_r = t_{r1} + t_{r2}
R_T is the length of the track. t_{r1} and t_{r2} are the times the rocket motor spent on the first and second halves of the track respectively. x_or , x_oj , v_or and v_oj are the initial positions and velocities, all equal to zero.
Mess around with this equations and you will find the answer.
Thanks, I really appreciate it, it worked out beautifully.
P.S. How did you write the equations like that? I only used my keyboard and that makes them hard to understand, next time I'd rather write the equations in clearly like you did to make it easier for others to see what I am doing.
Nevermind I just figured it out, it didn't work for me earlier because I had the script blocked, just had to unblock it. Thanks for the help though, I just needed that last t1 + t2 equation that you showed and everything fell into place :)
Glad to help.
This forum is \LaTeX-compatible. Check the last button with a sigma letter for some help. Actually, I recommend learning Latex altogether.
Great, definitely looks like something useful. Thanks
  • · Replies 38 ·
