Motors in series: how do you stop one motor from spinning?
The discussion centers on the mechanics of hybrid vehicles, specifically the Honda Insight's electric motor configuration. Participants clarify that when the electric motor is off, it does not act as a brake or clutch, allowing the gas engine to drive the vehicle without forcing the electric motor to spin. The design utilizes a common driveshaft where the electric motor's stator is stationary, and the rotor is connected to the wheels, minimizing drag when the motor is inactive. This setup is efficient, requiring no additional gears or clutches, and is compact in design.
  • Understanding of hybrid vehicle mechanics
  • Familiarity with electric motor configurations
  • Knowledge of driveshaft systems in automotive engineering
  • Basic principles of torque and rotational dynamics
  • Research the mechanics of series hybrid drive systems
  • Explore the design principles of the Honda Insight's drivetrain
  • Learn about electric motor operation in hybrid vehicles
  • Investigate the role of back EMF in electric motors
Automotive engineers, hybrid vehicle designers, and anyone interested in the mechanics of electric and internal combustion engine integration.
sfensphan
Hi All,
I've been reading up on hybrid vehicles and how the Honda Insight has an electric motor attached directly to the gas engine driveshaft. Their combined output causes the wheels to spin. My question is in regards to when the electric motor is off but the gas engine is on. Why doesn't the gas engine just force the electric motor to spin and the wheel to not move? I know there is some gearing involved, but I don't think the setup is non-backdriveable, and I don't believe there is a physical brake that clutches the electric motor. How about in situations where there is just direct drive? Do they just run the motor at a very low setting to prevent the electric motor rotation? That sounds like a stall scenario to me, and that would use a lot of power. How do you just use one of two motors in a serial configuration?
Would love to hear your guys' thoughts. Thanks very much!
... With the electric motor switched off, why wouldn't the drive shaft just turn the motor and the wheels? After all the shaft rotates with the engine, and is connected to both.
Series drivechains are done where both engines are ICE - how does that work if one of the ICEs is not switched on, but not disconnected? Could Honda engineers not use similar solutions?
How are you supporting this belief?
The engine and motor share a common driveshaft. When the motor is 'off', that just means it is spinning and not supplying power or acting as a regenerative brake. This design adds one bearing to the drive train and requires no additional gears or clutches. Very simple and compact.
Thanks Simon for taking a look. For your first question, I would expect the switched off motor to rotate (stator rotating with respect to the rotor), sort of acting like a bearing, with no work being done on the wheel itself. With the rotor and stator moving, it is acting like a generator. To lock the rotor and stator together, you would need to always have it on or have a clutch. From what I've read about the car, it doesn't seem to have a clutch in that location.
I'm mostly thinking about 2 motor cars being used in power saving mode or if one motor is broken.
Thanks dschlink. appreciate your thoughts. I should've clarified that the drivetrain setup is when the electric motor stator is attached to the ICE's output shaft. The electric motor's rotor is attached to the wheel. I think i understand the case where the electric motor adds power by a gear. I guess when one motor is off and not acting as a generator (so no back emf), the drag that induces is pretty minimal.
Where have you seen this arrangement used? It sounds like a rather inelegant solution. Your electric motor would need to have a torque output in excess of the ICE output to do any good.
BoB
It's not clear to me what you are describing here. A stator is stationary, and a rotor rotates inside it (on some motors the rotor is outside the stator). But regardless, the rotor and stator are concentric. So having the stator on the ICE output shaft, and the rotor on the wheel, makes no sense.
Maybe you are talking about two motor/generators?
  • · Replies 17 ·
10K
  • · Replies 24 ·
