MPPT algorithms, perturb and observe algorithm etc
7 replies · 4K views · last reply
PainterGuy
Hi,
I had thought that "hill climbing method" is a general terminology to refer to methods such as perturb and observe and incremental conductance. The same is also said here, "The hill climbing based techniques are so named because of the shape of the power-voltage (P-V) curve. This technique is sub-categorized in three types: Perturb & Observe Algorithm (P&O), Modified Adaptive P & O Method, Incremental Conductance Algorithm (INC)". [Reference #1, page #91: https://www.academia.edu/5691750/Hi..._point_in_Solar_Photovoltaic_Systems-A_Review]
But at many places they are considered two different methods, for example, "Perturbation and observation (P&O) and hill climbing methods are widely applied in the MPPT controllers due to their simplicity and easy implementation [2-3]. P&O method involves a perturbation in the operating voltage of the PV array, while hill climbing strategy introduces a perturbation in the duty ratio of the power converter [2] and is more attractive duty to the simplified control structure [4][Reference #2, page #804: https://www.researchgate.net/publication/224321861_Comparison_of_PO_and_hill_climbing_MPPT_methods_for_grid-connected_PV_converter]
Reference #2, page #805, also lists a flow diagram. Near the end it makes a distinction between perturb and observe algorithm and hill climbing by saying "For P&O MPPT Vref(k)=Vref(k+1)+Vstep*slope" and "For hill climbing MPPT D(k)=Dref(k-1)+Dstep*slope". I understand the hill climbing and how duty cycle is used to change the input voltage of panel to operate it at maximum power point. P&O changes the Vref instead of duty cycle but it can only change the Vref through duty cycle. For both methods, at the end od day, it's the duty cycle which regulates the voltage. So, does the difference only lie in the wording, or is there more to it? Could you please help me with this? Thank you.
Flowchart of an MPPT control system: sample V(k) and I(k), compute P(k)=V(k)*I(k), compare with P(k-1), complement slope sign when power falls, then update Vref for P&O or D for hill climbing, and update history values.
Reference #11: https://drive.google.com/open?id=1JQ4wQkA-M9PwBmRS6xHLhTBLZv3Dk7ou
Reference #2: https://drive.google.com/open?id=1qthgR8rW572jaaAjmvDFRvnkqtd10mZk
  • Flowchart of an MPPT control system: sample V(k) and I(k), compute P(k)=V(k)*I(k), compare with P(k-1), complement slope sign if power decreased, then update Vref for P&O MPPT or D for hill climbing MPPT, and update history values.
  • Flowchart of an MPPT control system: sample V(k) and I(k), compute P(k)=V(k)*I(k), compare with P(k-1), complement slope sign when power falls, then update Vref for P&O or D for hill climbing, and update history values.
PS:
https://www.google.com/search?q="Both+perturb+and+observe%2C+and+incremental+conductance%2C+are+examples+of+"hill+climbing"+methods+that+can+find+the+local+maximum+of+the+power+curve"&oq="Both+perturb+and+observe%2C+and+incremental+conductance%2C+are+examples+of+"hill+climbing"+methods+that+can+find+the+local+maximum+of+the+power+curve"
It includes results from Wikipedia and US solar institute.
Opening a Google drive file from a stranger is a security risk. You may not try any answers until you change that.
Thank you!
But I have more than 450 posts under my belt! :) Anyway, those Google drive files are PDFs and they are okay to open. Also, even an .exe file from Google drive doesn't open directly, you need to select download first.
Those Google drive files are the same as those Reference #1 and Reference #2 URLs in my post.
Finally, I have now attached the same files.
Best wishes,
PG
Don't take it personally. Each of us has a policy regarding risks on the Internet. Many PF members (me included) object to PDF files. Partially because on many of our platforms you must download the PDF before you can view it. There are also plenty of risks with PDF.
https://security.stackexchange.com/questions/72037/what-are-the-security-risks-associated-with-pdf-files#72071 said:
One PDF-specific risk is that Adobe and third-party reader extensions are supported: your PDF viewer may have extra modules loaded, or may require them to open certain documents. Examples include:
  • Adobe LiveCycle Rights Management ES4
  • https://stackoverflow.com/questions/6692676/is-there-a-way-to-set-a-time-limit-on-a-pdf for which there are commercial products
Both of these endeavour to constrain digital document use. At best, such features increase the attack surface, and at worst may deny you access to some of your files, report on your activity or otherwise take liberties with your privacy, documents, computer or network. (Sound familiar? Seems analogous to a browser and web page that needs Flash or a similar proprietary plugin.)
See also this question which covers PDF phone-home capability. Javascript, embedded multi-media (including, but not limited to Flash) and Xobjects (external streams) are at least some of the ways to achieve that.
Some less-obvious risks associated with, but not entirely specific to PDFs:
  • PDFs can http://blogs.adobe.com/insidepdf/2010/11/pdf-file-attachments.html, though not all readers support this, and those that do don't always visually indicate their presence. These can be any type of file, including another PDF. An encrypted PDF (commonly RC4 or AES) is identifiable as a PDF (only the data streams are encrypted, rather than the file as a whole), the presence of attachments is not evident in this case. Behaviour is restricted on some platforms at least, see Adobe's KB 331371 and KB 328671. (I consider this is a potential risk because it comes as a surprise to many people, and it may be used for stealth transfer.)
  • Misplaced faith in native "security features" such as no-copy, no-print, no-edit. These are effectively discretionary controls, at the discretion of the viewer software itself.
  • The structure/layout of the PDF format is quite loose, and PDF lends itself to use and abuse as a chameleon or polyglot format (PDF), see Corkami's examples here:http://code.google.com/p/corkami/wiki/mix?show=content . This show files which are simultaneously PDF, native binary executable, .jar and .html by using similar "slack" in those formats.
  • Metadata may leak information about the document origins or history. http://blogs.adobe.com/security/2009/12/how_to_properly_redact_pdf_fil.html is also problem.
  • Support for rich content (multimedia via Flash, embedded fonts) and browser integration facilitate attacks on client-side software components beyond the reader/viewer itself
...One PDF-specific risk is that Adobe and third-party reader extensions are supported: your PDF viewer may have extra modules loaded, or may require them to open certain documents. Examples include:
In summary:
  • PDFs are feature rich, and the implementation potentially complex, both of which contribute to an increased attack surface
  • support is multi-platform and since it continues to be the de-facto document format, approaching ubiquitous, making it a popular target
  • PDFs provide a vector for attack payloads (Javascript, multi-media, attachments etc) both by design, and by accident
The result of the above (combined with the near legendary bloat of the canonical PDF reader) can been seen in the CVE statistics for Acrobat/Reader.
Thank you! No problem. I didn't take it personally. :)
Actually I included those Google drive PDFs for the same URL documents was that sometimes sources get deleted over time and in such a case a thread might become almost useless to someone who stumble onto it. Also if I attach PDFs here on PF then first you need to download those files fully which I believe is more risky compared to opening a PDF on Google drive.
I would say "hill climbing" is as far as I understand, the overall method, of which perturb and observe is one of.
Thank you.
I have also looked many places and it looks like perturb and observe is one of hill climbing methods.
