Multi-Variable Limits: Evaluating Limits at (0,0) with a Zero Denominator
  • Thread starter Thread starter snoggerT
    Limits Variable
The discussion revolves around evaluating a multi-variable limit as (x,y) approaches (0,0) for the expression (sinx)(siny)/(xy). Participants express uncertainty about handling limits with a zero denominator and explore various approaches to understand the behavior of the limit in this context.
  • Participants suggest using substitutions, such as letting x=y or approaching along different paths like y=mx. There are discussions about the validity of separating variables and using polar coordinates to evaluate the limit. Questions arise regarding when it is appropriate to apply the product rule and the implications of approaching the limit from various paths.
The discussion is active, with participants exploring different methods and questioning the assumptions behind multi-variable limits. Some guidance has been offered regarding the use of polar coordinates and the need for consistent results across multiple paths to establish the existence of the limit.
Participants note the complexity of multi-variable limits compared to single-variable limits and express frustration with the transition to more challenging concepts in calculus. There is an emphasis on understanding the conditions under which certain limit laws apply.
snoggerT
Evaluate the limit or determine that it DNE
lim as (x,y) goes to (0,0) of [(sinx)(siny)]/(xy)
I can solve these when the denominator isn't zero, but pretty much rest of my homework deals with that situation. I'm really not sure how you solve multi-variable limits when you get a zero in the denominator. I know that with single variable limits you use L'hospital, but I'm not sure if that is possible in these situations. So I really need help with this.
let x=y, then lim as x,x -> 0,0
Try to get rid of either one of variables by using a suitable substitution. For example, you need not approach the origin along the y or x-axis. Try approaching the origin along the line y=mx. Make that substitution and let x approach 0, then find that limit. Try evaluating the limit in polar coordinates as well, and r approach 0 regardless of the value of theta. What do you get for both?
A multivariable limit exists at a point if you find the same value by approaching that point from any path. (It's analogous to, but more complicated than, the situation with one variable, where you simply have to have the same limit as you approach the point from either side.
Do you know the limit of (sin x)/x as x approaches 0? This function could be written as a product of two such functions. Would the limit give the same value no matter how you chose to approach x = 0 and y = 0? What would that limit be?
Letting y= x and then x-> 0, or more generally, letting y= some function of x and then x-> 0, does NOT prove that limit exists. It is quite possible for the limit to exist along one curve through (0,0) and then not exist along another, or exist but have a different limit. Of course, if you could take the limit along two different paths and either show that the limit along one does not exist or that the two paths give different limits, they you would have shown that the limit does not exist.
Unfortunately, if you took the limit along many different paths and always got the same limit, that would not prove that some path you hadn't tried wouldn't give a different limit.
Generally, with limits going to (0,0) where you suspect the limit does exist (maybe you tried several paths and always got the same thing) the best thing to do is to change to polar coordinates. That way, the "nearness to (0,0)" is completely determined by r. If the limit as r goes to 0 is independent of [itex]\theta[/itex], then the limit exists and that value is the limit.
HOWEVER, in a very simple case like this you can simply "separate" the variables:
[tex]\lim_{(x,y)\rightarrow (0,0)}\frac{sin(x)sin(y)}{xy}= \left[\lim_{x\rightarrow 0}\frac{sin(x)}{x}\right]\left[\lim_{y\rightarrow 0}\frac{sin(y)}{y}\right][/tex]
And surely you know those two limits from Calculus I!
(You will soon be seeing much more difficult limits than this!)
Under what circumstances would it be valid to separate the mutivariable limits and evaluate them individually?
- I would also like to know when you're able to use the product rule for these types of problems. I think my biggest problem right now is that I'm not sure what techniques are legal for these problems. Calculus has been pretty simple for me until this class, so it's frustrating that I haven't been able to just teach myself rather quickly.
Product rule? Ivy simply splitted the terms in a x-part and a y-part.
Try this one:
[tex]\lim_{ (x,y) \rightarrow (0,0)}\ \frac{x+y}{ \sqrt{x^2 + y^2}}[/tex]
Try this one:
- Sorry, read that part wrong in the book. I meant to ask when you could treat it as a product of functions of one variable. I'm about to head to class, so I'll try to work on that problem while I'm waiting for class to start.
What Ivy did is generally speaking not always possible. If you can split the limit in one part only dependent on x and another one dependent on y you can try to take the limit of those terms separately.
Hey when you use polar coordinates here. What about the value of theta, my sir was telling something about the value of theta between 0 and 2 pi
All of the normal limit laws happen with multivariables? Would that be usefull?
  • · Replies 19 ·
