Group Theory: Multiplicative Cosets Explained
  • Context: Undergrad
  • Thread starter Thread starter Mr Davis 97
    Cosets
This discussion focuses on the concept of multiplicative cosets in group theory, particularly in the context of rings. It establishes that while additive cosets are commonly studied, multiplicative cosets can also be investigated, although they present challenges due to the nature of multiplication in rings not forming a group. The necessity for subsets to be ideals for multiplicative cosets to behave properly is emphasized, highlighting the complications arising from zero divisors and the lack of inverse elements. Ultimately, the conversation illustrates the importance of understanding the structure and properties required for defining multiplicative cosets.
  • Understanding of group theory concepts, particularly cosets
  • Familiarity with ring theory and the properties of rings
  • Knowledge of ideals in the context of rings
  • Basic grasp of binary operations and their implications in algebra
  • Explore the definition and properties of ideals in ring theory
  • Study the structure of multiplicative groups in division rings
  • Investigate the role of zero divisors in ring multiplication
  • Learn about normal subgroups and their significance in group theory
Mathematicians, students of abstract algebra, and anyone interested in deepening their understanding of group and ring theory, particularly in relation to cosets and their structures.
Mr Davis 97
In learning group theory, you learn about cosets as a partition of the entire group with respect to a subgroup. Since we are dealing with groups, there is only on operation that can be used to form the cosets. But when we come to rings, we now have two operations. So my question is, why do we only care about additive cosets, as opposed to defining multiplicative cosets and investigating them?
You can investigate multiplicative cosets as well. This is frequently done in group theory. I don't know why you should think that we only consider additive cosets.
Because multiplication in a ring isn't a group. It is nothing more than an arbitrary binary operation. O.k. it's distributive and usually associative, but that's it.
However, if we look at the subsets ##U \subseteq R## of a ring, for which cosets usually are considered, we find, that ##U## is required to be an ideal. And as such ##r\cdot U \subseteq U## is required, i.e. the multiplication at least should behave nicely.
If we considered multiplicative cosets only, without being additive, then we would run into difficulties, as the ring multiplication isn't a group structure. First we will probably exclude ##0##, because this element doesn't belong into multiplication and damages everything there. But what to do next with zero divisors? So let's say we have an integral domain. But what should a typical ##U## be? We don't have inverse elements, so is it any arbitrary set? Then what for should it be good to look at it? If we continue this way, by requiring new conditions if needed, we will probably end up with the multiplicative group of a division ring, which is just a multiplicative group that is already considered in the realm of group theory.
It is an enlightening exercise to try to define a well-defined structure on ##\{r\cdot U\}## and to see in the process, which properties are actually needed and what for. This holds also true for groups. It demonstrates the difference between an ordinary subgroup and a normal subgroup. In doing so, one can actually see, why this at first glance deliberate condition of normality actually comes into play!
  • · Replies 26 ·
  • · Replies 17 ·
9K
