Multiplicity of an eigen value , k = dim[ Null(T - k I)^( dim V) ]
  • Thread starter Thread starter vish_maths
    multiplicity Value
The discussion centers on proving that the multiplicity of an eigenvalue \( k \) is equal to the dimension of the null space of \( (T - kI)^{\dim V} \). Participants explore the relationship between eigenvectors, their linear independence, and the geometric versus algebraic multiplicity. Key insights include the clarification that not all generalized eigenvectors are linearly independent, and the dimension of the null space indicates the number of linearly independent generalized eigenvectors. The conversation references Sheldon Axler's "Linear Algebra Done Right" and Theorem 8.10 regarding upper triangular matrices.
  • Understanding of eigenvalues and eigenvectors
  • Familiarity with null spaces and linear transformations
  • Knowledge of Jordan normal form and its implications
  • Concept of geometric and algebraic multiplicity
  • Study the implications of Jordan normal form on eigenvalues and eigenvectors
  • Learn about the relationship between null spaces and generalized eigenspaces
  • Research the proofs of Theorem 8.10 and Corollary 8.7 in linear algebra
  • Explore examples of linear transformations with repeated eigenvalues
Students of linear algebra, mathematicians, and educators seeking a deeper understanding of eigenvalue multiplicity and its implications in linear transformations.
vish_maths
Prove without induction that Multiplicity of an eigen value , k = dim[ Null(T - k I)^( dim V) ]
[(T - k I)^dim V ] v =0
[Thoughts]
i understand that normal eigen vectors with same eigen values may not be
linearly independent.
then, the fact that k = dim[ Null(T - k I)^dim V ]
somehow gives an intuition that in this case, the Eigen vectors with
the same Eigen value k are linearly independent ?
This is confusing to me.
If i can know, that for [(T - k I)^dim V ] v =0 , the solutions are
linearly independent, then the desired result can be proved.
OR if i prove that the solutions to the above equation are eigen vectors which form a basis, then i have the solution.
What could be a direction ?
[Thoughts]
What's your definition of 'multiplicity'? I would define geometric multiplicity to be the dimension of the space spanned by the eigenvectors with eigenvalues k. That would just be dim(null(T-kI)). How do you define it?
I would define multiplicity as the number of times an eigen value is repeated in an upper triangular matrix..
Ah, ok. So it's really more like an algebraic multiplicity. If you write the matrix is Jordan normal form, then it should be pretty easy to see. The blocks with k along the diagonal in T will get 0 along the diagonal in T-kI. So taking it to a high enough power will turn them into blocks of zeros. Sound right?
Hi, the Book which i am reading Sheldon Axler's Linear Algebra done right, they haven't introduced the jordan form as of yet. But have proved this result with induction. However, it does not sound convincing enough.
I know these facts : ( Let * imply contained in )
then : Null T0 * Null T1 *...*Null Tdim V = Null Tdim V + 1 = ...
Can i prove it from these results ?
Where are you exactly in your book? Where in the book does this question pop up??
Are you allowed to use either Theorem 8.10 or Corollary 8.7 (because they prove exactly what you state here).
Hi, I am on Pg 169 Theorem 8.10 which has been proved using induction.
I am allowed to use just Corollary 8.7 which states that :
Suppose T belongs to L(V) and k is an eigen value of T, Then the Set of generalized eigen vectors of T corresponding to k equals null ( T - k I )dim V
Can we prove that the generalized eigen vectors with same eigen value k are linearly independent ?
Thanks.
That's simply not true. Not all generalized eigenvectors are linearly independent. However, you can always find a basis of the generalized eigenspace.
If not all generalized eigen vectors are linearly independent, is it right to say that
dim[ Null(T - k I)( dim V) ] is the number of eigen vectors with eigen value k.
Suppose, two eigen vectors with eigen value = 5 are linearly dependent
We expect that dim[ Null(T - 5I)( dim V) ] = 2
which means that these two vectors should actually be linearly independent ?
I am finding this a bit confusing.
Thanks
That's never correct to say. I don't really understand where you got this. The quantity \alpha = \dim(Null (T-kI)^{dim~V}) is the dimension of the generalized eigenspace. Which means that a basis of the generalized eigenspace will have consist of exactly \alpha vectors. So you will always be ablefind at least and at most \alpha linear independent generalized eigenvectors.
Why? This makes no sense.
Saying that that dimension is 2 only means that there exists two linearly independent generalized eigenvectors. It does not say that there are only two generalized eigenvectors. It does also not say that any 2 eigenvectors are linearly dependent or independent.
Theorem 8.10 says that Let T belong to L (V). Then for every basis of V with respect to which T has an upper triangular matrix , k appears on the diagonal of the matrix of T precisely dim null ( T - k I )dim V
Precisely, this is how i understand this : We know that the eigen vectors with the same eigen values may not be linearly independent and that is why dim null ( T - k I ) will not correctly yield the number of times k is repeated.
Now, How exactly is dim null ( T - k I )dim V = number of times the eigen value k has repeated in the upper triangular matrix ? in the background, we know ( let's assume ) that the corresponding eigen vectors are linearly dependent
