Multiplier for the whole integral
  • Thread starter Thread starter Muppetmaster
    Integral
5 replies · 2K views
Muppetmaster
[itex]\pi[\int \right[ \frac{\sqrt{x^2+1}}{x^4+sin(x)^2}\left]\;dx[/itex]
As above
Is there some sort of identity not sure even where to start this one?
Sorry that pi is obviously meant to be a multiplier for the whole integral if that isn't clear.
It's not actually outside per se.
You can easily put it before the dx in a relevant format relation to the equation.
It's just a constant outside the integral instead of inside so think of it as the +C if that helps.
rock.freak667 said:
Where did you get this integral from? By observation, it looks like an integral without an elementary anti-derivative.
In an advanced textbook, I assume there is a solution but it might as you say be some sort of Taylor series type equation?
I admit it's not technically homework but I thought this would be the place to put it?
wolfram says "No!" :P
Given that you're adding a power of x to a trigonometric function of x in the denominator, I doubt it would be doable. You could of course do a series expansion around some point and integrate each term in the series individually, but I'm not sure if you'd be able to find a closed-form expression for all the series coefficients.
