I Multiplying a vector by a complex number
Multiplying a vector, such as 3i + 4j, by a complex scalar like 2 + 5i requires the vector to have complex coordinates for the operation to be meaningful. The result of this multiplication can be expressed as two separate components, one for the real part and one for the imaginary part. While multiplying by a real scalar expands the magnitude of the vector, multiplying by a complex scalar does not have a straightforward geometric interpretation, such as rotation or expansion. Instead, it alters the vector's components without changing its geometric properties in a conventional sense. Thus, the operation is valid in complex vector spaces but lacks the intuitive geometric implications associated with real scalar multiplication.
topito2
I have learned that if I multiply a vector, say 3i + 4j, by a scalar that is a real number, say 2, the effect of the operation is to expand the size of the magnitude of the original vector, by 2 in this case, and the result would be 6i + 8j.
What would be the effect on a vector, like 3i + 4j, if I multiply it by a scalar that is a complex number, say 2 + 5i?
Mathematics news on Phys.org
If you have a scalar ##z##, be it real or complex, and multiply with a vector ##v = \sum_{i=1}^N v_ie_i## where ##N## the dimension of the vector, ##v_i## the i-th component which can be real or complex scalar, and ##e_i## the i-th basis (unit) vector, the result will be ##zv = \sum_{i=1}^N (zv_i) e_i##.
Note that there is possible confusion in your notation, you use ##i## both for denoting the component of a vector and the imaginary number ##i=\sqrt{-1}##.
When you multiply by a complex number you essentially create a dyad of vectors ##(v_1,v_2)## one for the real part (##v_1##) and one for the imaginary part (##v_2##), where in your example it would be ##v_1=2(3i+4j)=6i+8j## and ##v_2=5(3i+4j)=15i+20j##
For this operation to have meaning, you would need to consider your vector to have complex coordinates. So in your vector, the "6" is in reality (6 + 0i) etc.You will find that most vector operations will be the same when using complex coordinates.
Except
The scalar product (dot product) will have a slightly different definition. Instead of \vec{a}\cdot \vec{b} =\sum_{k}a_{k}b_{k} the definition is \vec{a}\cdot \vec{b} =\sum_{k}a_{k}\bar{b}_{k} where the bar denotes complex conjugation.
It is probably better to rename the parts of your vector: 3x+4y. Then your multiplication gives (6+10i)x + (8+20i)y. Your vector space has to be a vector space over the complex numbers to make such a multiplication meaningful.
thank you so much for your quick responses, guys! you have been very helpful.
so according to what you have exposed, there is no geometrical interpretation for multiplying a vector (with real numbers as components) by a complex number? performing that kind of operation won't make the vector to have an expanded magnitude, to rotate, or something else?
Not that I know of.
A vector with real components is an element of a vector space over the field of real numbers. I.e., the components of the vector are real numbers. The basic operations on such a vector space are vector addition and multiplication by scalars (real numbers in this case).
A vector with complex components is an element of a vector space over the field of complex numbers. The basic operations are the same as above, except that scalar multiplication includes multiplying by complex scalars.
Thank you so much for your help!
