Can Multisim Import and Process Sound Files Through a Circuit?
  • Thread starter Thread starter houlahound
    files Sound
Multisim may allow the import and processing of sound files through circuits, such as a passive low pass RC filter, enabling output to a speaker and saving the clean signal as a WAV file. Users can typically input data from files into simulations and utilize functions like $read and $write to manage data. However, specific commands and capabilities in Multisim are unclear, as the discussion references another simulator, ncsim, which has different functionalities. It is suggested to consult the NI Multisim forums for more precise guidance on accessing file data. Overall, while the potential exists, detailed knowledge of Multisim's features is necessary to achieve the desired outcome.
houlahound
Is it possible to import a sound file into multisim and run it thru a circuit eg a passive low pass RC filter and send the signal to a speaker and save the clean signal say as a wav file.
You can generally input data from a file into a simulation, operate on it, then capture that data to a signal and write it to a file. You can then convert it to whatever format you choose.
The actual commands to do that depends on the simulator, but it is basically learning to make use of the various $read and $write simulator functions.
Not sure what multisim has available, if anything.
For example the following (from an ncsim file, not multisim)
$fwrite(tester_vectorsFPGA_filehandle,"%s %s %b %b //%0d\n",dpstringFPGA, dmstringFPGA, txoe, testeroe, vector_num12);
will write to the file represented by the filehandle: two strings (contained in dpstringFPGA, dmstringFPGA) , and 2 binary values (contained in txoe, testeroe) and a decimal value vector_num12
You just capture the data into a variable at each clock edge, and write it out.
You do a similar thing to read a file into a 2 dimensional array, then iterate through the array on each clock edge (or as you need the data).
Generally the array needs to be large enough to hold the whole file.
Others may have more experience with multisim.
Is ncsim a circuit simulator?
Not sure if it is valid code language but I read a lot of random symbols in yr code.
Same happens to math eqtns I read here so I think it is prob my end.
ncsim is a Cadence multilanguage simulator that I use at work.
I guess what I wrote won't help you with multisim. Sorry.
I recommend you ask your question in the NI multisim forums. I assume there are symbols to access file data for read and write, but I don't know how to do it.
Links to Cadence overview?
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 31 ·
