Which Math Book Should I Get for Multivariable Calculus?
The discussion centers on the best approach to learning multivariable calculus before tackling analysis in "Baby Rudin." The participant currently knows only single-variable calculus and is considering resources to bridge the gap. Suggestions include "Calculus Vol. 2" by Apostol for its rigor, though it may be time-consuming, and Lang's "Calculus of Several Variables" for a less rigorous introduction. However, both texts do not cover differential forms, which are also deemed challenging to learn from Rudin. An alternative recommended is Hubbard's "Vector Calculus, Linear Algebra, and Differential Forms," noted for its good reputation. Additionally, it is advised to avoid learning measure theory and Lebesgue integration directly from Rudin, with Bartle's "The Elements of Integration and Lebesgue Measure" suggested as a better resource. Overall, the consensus leans towards completing foundational topics before diving into more complex material in Rudin.
GeneralOJB
I am currently reading baby Rudin, but I only know single-variable calculus at the moment, so I think it would be a good idea to learn the multi-variable stuff non-rigorously before I do the analysis in Rudin (chapters 9-11).
So I was thinking of either getting one of the many 'Mathematical methods for...' books or 'Calculus vol.2' by Apostol. Which would be better?
Why not a cheap book like the following one? I'm thinking, why not finish with the single-variable topics first, get them done and out the way, then learn the multivariable material rigorously from the start? I mean, you're learning analysis so you might as well put it to use.
https://www.amazon.com/dp/0486457958/?tag=pfamazon01-20
Yes, I was planning on doing that, I thought it might be quite difficult to learn it straight from Rudin though. I'll see how it goes.
Apostol is pretty rigorous and it will take you quite a while to hack your way through. If you want a less rigorous but really excellent introduction, get Lang's Calculus of Several Variables.
Neither Apostol nor Lang does differential forms, though, and Rudin would be a horrible place to learn this (or any of the material in chapters 9-11, for that matter). An alternative would be Hubbard's Vector Calculus, Linear Algebra, and Differential Forms: A Unified Approach, which I have not read but which has a very good reputation. Personally I don't see the point of trying to learn differential forms without having learned the "classical" treatment as in Lang, but that's just my preference.
If I recall correctly, Rudin does measure theory and Lebesgue integration in chapter 10 and/or 11. None of the above books will help you with this, and I would NOT advise learning it from Rudin. Almost any other book covering this material will be a better choice. A nice efficient (but expensive) choice would be Bartle's The Elements of Integration and Lebesgue Measure.
I'd skip chapters 9-11 of Rudin. The materials are better treated elsewhere.
You'll need vol 1 and vol 2 of Apostol for complete treatment of multivariable calculus.
i am self learning physics. have you ever worked your way backwards again after finishing most undergrad courses? i have textbooks for junior/senior physics courses in classical mechanics, electrodynamics, thermal physics, quantum mechanics, and mathematical methods for self learning. i have the Halliday Resnick sophomore book. working backwards, i checked out Conceptual Physics 11th edition by Hewitt and found this book very helpful. What i liked most was how stimulating the pictures...
10K
  • · Replies 30 ·
