Muon special relativity problem,
The problem involves muons traveling from a height of 10 km above the Earth's surface and requires determining their velocity in relation to the speed of light so that a specific number of them arrive undecayed. The mean lifetime of a muon is given, and participants are exploring the implications of special relativity on this scenario.
  • Mixed
  • Participants discuss the application of the decay equation and Lorentz transformations to relate the time in the muon's rest frame to the Earth frame. There is confusion regarding the use of specific equations and transformations, as well as the calculation of the velocity of the muons.
Some participants have made progress in their calculations and have arrived at a velocity for the muons, while others are still grappling with the transformations and equations involved. There is a mix of understanding and uncertainty, with some participants questioning the validity of certain approaches and equations.
Participants are working under the constraints of the problem's parameters, including the mean lifetime of the muons and the requirement for a specific number to arrive undecayed. There is also mention of potential inaccuracies in the assumptions regarding the speed of light.
StonedPhysicist
Member warned about lack of template
Here is the question:
If 1000 muons are incident from a height of 10 km above the Earth's surface, how much slower than the velocity of light must they be traveling in the rest frame of the Earths surface for 990 of them to be expected to arrive at the ground undecayed? The mean life of a muon is 2.2 microseconds. You can use equation: (gamma)(beta)=sqrt((gamma)^2+1) for (gamma) much greater than 1.
I can't seem to work out how to do this. So far I used the decay equation to find the time taken for the 1000 muons to decay to 990 muons as 2.21x10^-8 seconds but i am not sure where to go after this, help will be greatly appreciated.
The 22.1 ns you found is in the rest frame of the muons. You need a Lorentz transform to the Earth frame, where that time is 10 km / v
Must admit I don't understand the fun of using ##\gamma\beta\approx \sqrt{\gamma^2+1}## when I know that ##\gamma\beta=\sqrt{\gamma^2-1}##
can you explain how to do the transformation? , i have the formula ct'= (gamma)(ct-(beta)x) but don't see how to do it
Muons are at rest in their own frame, so x = 0. Makes it easy, doesn't it ?
More nice info here
More nice info here
using ct=(gamma)(ct'+(beta)x') subbing in x'=0 , t=10km/v i end up with: v=10/(gamma)t' BUT I do not know gamma? so cannot complete the calculation? or am i missing something?
##\gamma = \sqrt{1\over {1-\beta^2}}\ ## and ##\ \beta = {v\over c}##
And the distance covered by the muons in the Earth frame is a lot more than 10 m !
yes thankyou! finally i got the answer that the velocity of the muon is 66 m/s less than c (in the rest frame)! woo!
In the Earth frame...
and, as you see, ##\beta\gamma = \gamma## for all practical purposes
I follow the reasoning for this.
The radioactive decay equation gives us ##N=N_0e^{\frac{-t'}{t_0}} \rightarrow t'=2.21*10^{-8}s##
This is the time in the rest frame of the muon.
Then using the Lorentz transformations : ##t = \gamma t'##
##v=\frac{d}{t} \rightarrow v=\frac{d}{\gamma t'}##
How has he managed to find v from ##\gamma=\frac{1}{\sqrt{1-\frac{v^2}{c^2}}}##?
I've tried many different rearrangements and haven't managed to pull v out of it, I must be doing something wrong.
##\gamma v = \frac{d}{t'} = \frac{10*10^3}{2.21*10^{-8}}##
EDIT:: ##\frac{v}{\sqrt{1-\frac{v^2}{c^2}}} = \frac{d}{t'}##
##v(1-\frac{v^2}{c^2})^{\frac{-1}{2}} = \frac{d}{t'}##
##v^{-2}(1-\frac{v^2}{c^2})=(\frac{d}{t'})^{-2}=\frac{t'^2}{d^2}##
##v^{-2}-\frac{1}{c^2}=\frac{t'^2}{d^2}##
##v^{-2}=\frac{t'^2}{d^2}+\frac{1}{c^2}##
Skipping a few steps of algebra...
Therefore ##v=\sqrt{\frac{d'^2*c^2}{c^2t'^2+d'^2}} = 299999934.1##
And ##c-v = 66 m.s^{-1}##
I have finally worked it out too!
Of course this is all assuming that that speed of light is ##3*10^8 m.s^{-1}## which it isn't... so I'll have to work something different out
  • · Replies 22 ·
