Murray Gell-Mann on Entanglement
  • Context: Undergrad
  • Thread starter Thread starter Thecla
    Entanglement
421 replies · 36K views
stevendaryl said:
But that theory isn't standard QM, it's a proposed alternative theory.
I don't claim anything for GRW. It has a passing similarity to what I was thinking.
secur said:
Anyway Demystifier's statement is justified. A traditional classical physicist - such as Einstein - considers it "cheating" for QM to simply refuse to predict (one single) experimental result. If we ever come up with a new, deeper, theory that can do that, Demystifier's (and Einstein's) point would become obvious and accepted by all. Until then, it remains rather subtle and requires some cogitation to appreciate.
I think one has to realize that this point is absolutely standard, and that one can take Bohr or Einstein's view coherently. What is being debated here is whether the claims by vanhees71 (following Ballentine), arnold neumaier etc are correct - their views do not fall into either the class of Bohr or of Einstein's. Certainly, they are not textbook views - one would have to believe that Bohr, Einstein, Dirac, Landau & Lifshitz, Cohen-Tannoudji, Diu, Laloe, Bell, Weinberg etc all failed to understand quantum mechanics.
secur said:
I certainly thought that in classical relativistic physics the past light cone(s) of the objects in question (including the space, of course, with its curvature; and the stress-energy tensor) contain all info that could possibly affect the physics. And, theoretically perfect prediction is possible. (In fact given that the theory is local all you really need is "here-and-now" information - anything in contact - but that's not relevant at the moment). Can you please explain further?
[EDIT] assume there's only one inertial frame used for both observations and predictions ... I can't think of any other loopholes I might be missing
Maybe he's referring to "cosmic censorship" scenarios in general relativity, it's the only example I know of where that stops being true.
stevendaryl said:
Do they? That would seem to mean that if you are trying to measure the spin of an electron, then initial conditions in the measuring device determine the final measurement result. That's a kind of hidden-variable theory, except that the variable is not in the thing being measured, but in the thing doing the measurement.
You misunderstand. The initial conditions happen after preparation and before measurement.
stevendaryl said:
But my claim is that there is nothing in quantum mechanics that would then select a single alternative out of the set of possibilities described by that mixed state.
Yes there is: the so-called collapse, when a measurement is made. Of course you mean, apart from that.
Mentz114 said:
If you allow dissipative sub-systems in QT then it is the initial conditions that decide the outcome.
GRW posits spontaneous collapse. Presumably that has a "passing similarity" to your "dissipative subsystems"? But stevendaryl's response applies equally well to your idea, as to GRW:
I don't see how that could work. If an electron being spin-up causes a detector to enter state [itex]UP[/itex], and an electron being spin-down causes a detector to enter state [itex]DOWN[/itex], then by the linearity of the evolution equations of quantum mechanics, an electron in a superposition of spin-up and spin-down would cause a detector to enter into a superposition of states [itex]UP[/itex] and [itex]DOWN[/itex], if there is nothing going on in the detectors other than ordinary quantum mechanics.
Of course, something macroscopic like a detector will interact with the environment, which enormously complicates things. But the same thing applies to electron + detector + environment: Linearity of quantum mechanics would that the composite system will enter into a superposition. So, we would end up with a superposition of two different composite states: [itex]|\psi_{up}\rangle[/itex], where the electron is spin-up, and the detectors detects spin-up, and the environment is whatever condition is appropriate for the environment interacting with a detector that detected spin-up, and [itex]|\psi_{down}\rangle[/itex], where all three components are in states appropriate for the electron being spin-down.
It doesn't make sense to say that details of the detector, or the environment, will cause it to shift to just one "branch". That would violate the linearity of the evolution equations. You could propose new, nonlinear corrections to quantum mechanics that might accomplish the kind of objective collapse that you're talking about, but it isn't possible in standard quantum mechanics. (Unless you consider wave function collapse to be part of standard quantum mechanics, which some people do.)
Right, the issue is whether a separate "collapse" hypothesis is needed, or whether the effect of collapse is derivable from just unitary quantum evolution.
I'm sorry, your comment seems orthogonal to my post. Please make the connections (which, no doubt, exist) explicit, if you like.
This brings up an interesting point. "Cosmic Censorship" - which of course is only a conjecture - proposes that a naked singularity never happens. Therefore if the evolution of some system would lead to that, it won't - instead it will do something else. On the face of it that sounds like Nature must "look ahead" to see the result of some process, and if Nature sees that it will be "censored", then it changes the (other) laws of physics in this one instance, to avoid that "illegal" outcome. That's teleology.
Ignore QM entirely for this discussion, stick to purely classical, because QM can confuse the following points I want to make.
For perspective consider the conservation laws of energy and momentum, applied to a couple of (perfectly elastic) billiard balls. As we all know you can determine how they'll bounce off each other most easily by applying those conservation laws. The two resulting simultaneous equations are easily solved. But certainly we don't normally think that Nature does such a look-ahead computation. Rather the billiard ball trajectories evolve via differential equations, "contact transformations", according to Newton's laws of motion and the law of elastic collision. Nature never "looks ahead" during this process. But it so happens that, when the collision is done and the balls are heading off to infinity, energy and momentum have been conserved.
There are many similar examples, e.g. various forms of the Action Principle. Many places where by solving the original dynamical differential equations we come up with (very useful) global constraints, expressed as integral equations. Loosely we say that Nature "must obey" these. But - in the normal ontology of classical physics - we don't imagine Nature is looking ahead, beyond the past light cone, to decide what to do. The instant-by-instant diff EQ's are all Nature knows about.
It's the same for Cosmic Censorship. If it's true that Nature never "allows" a naked singularity, it must happen due to ordinary physical laws (including, perhaps, currently-unknown ones) which operate only on the currently available info (past light cone) in such a way that, it turns out, naked singularity never happens.
You may be right that A. Neumaier is thinking of something like this; of course, we don't know. I was planning to give the above answer if he did respond as you suggest.
This general issue of "teleology in physics" is wandering off-topic; there's a lot more one could say about it. Bottom line, I think it should always be viewed as merely a convenient heuristic - sometimes very convenient - but Nature never really does "look ahead". Ignoring QM, where it's not so clear.
For what my opinion's worth, it seems very clear that mere unitary quantum evolution can't do it. You need an extra hypothesis to explain the collapse. Every alternative interpretation has one - including MWI, despite their claim that they don't.
stevendaryl said:
There is nothing in quantum mechanics that bounds the standard deviation of a variable such as position. A single electron can be in a superposition of being here, and being 1000 miles away. A single atom can be in such a superposition. A single molecule can be in such a superposition. There is nothing in quantum mechanics that says that a macroscopic object can't be in such a superposition.
See the new thread https://www.physicsforums.com/threads/the-typical-and-the-exceptional-in-physics.885480/
ddd123 said:
it's unclear where the pure superposition is supposed to end.
It is nowhere there in the first place. It is an artifact of the initial idealization.
One needs the information on a Cauchy surface, not on the past light cone, to make predictions. More precisely, to predict classically what happens at a point in the future of a given observer, the latter's present defines (at least in sufficiently nice spacetimes) a Cauchy surface where all information must be available to infer the desired information.
it is no different in quantum mechanics when one makes (probabilistic) predicions. The apex of the light cone is the point in space-time at which all information needed to do the statistics is available. See https://www.physicsforums.com/posts/5370260 and the discussion there between post #187 and #230.
stevendaryl said:
Under what circumstances does an electron measure its own spin? Never, right? So it doesn't make any sense at all to say that an isolated electron has a 50% probability of being spin-up in the z-direction. What about a pair of electrons? When does one electron measure the spin of another electron? Never, right? So for a pair of electrons, probability doesn't make any sense.
Probability only makes sense for an interaction in which one of the subsystems is a macroscopic measuring device.
You measure the spin, e.g., with a Stern-Gerlach apparatus, which leads to an entanglement between the spin component and the position of the particle, which then can be detected. All you know about the outcome of such a measurement is that with 50% probability you find the one or the other possible value of this quantity. Of course, this doesn't tell you much (in fact as little as possible in the sense of information theory) about a single spin. Probabilities in practice are relative frequencies of the occurrence of the property when you perform measurements on an ensemble of independently prepared spins in this state. I don't know, why we have to repeat this all the time in our discussions. It's common practice with all experiments in all labs around the globe!
stevendaryl said:
To me, if you and your equipment are all described by the same physics as electrons and photons, etc., then to say that "I prepared things in such-and-such a way" means "Me and my equipment were put into such and such a macroscopic state". So there is a notion of "state" for macroscopic objects that does not depend on yet another system to prepare them in that state. They can put themselves into a particular state. But you're saying that for an electron, or a photon, or any microscopic system, the only notion of state is a preparation procedure by a macroscopic system. That seems incoherent to me. At best, it's a heuristic, but it can't possibly be an accurate description of what's going on. If macroscopic systems have properties without being observed, then why can't microscopic systems?
Common practice today discproves you. It has become more and more possible in the recent decades to handle single particles and photons and prepare them in many kinds of pure and mixed states, everything in accordance with standard QT.
So are you saying that particle (microscopic system) can acquire definite quantum state spontaneously?
According to Ballentine, it is really the case that all these mentioned men failed to understand quantum mechanics properly.
Each of them (including Ballentine) has a slightly different view of QM. Personally I like the Bell's view the most, but I see some merits in all of them.
vanhees71 said:
No, they require a definite quantum state by being prepared in it. I don't know what you mean by "spontaneously".
With "spontaneously" I mean property of macroscopic systems to prepare themselves in definite state as suggested by stevendaryl:
That's definitely not true. My view is very conservative and minimal. Weinberg's point of view is, according to his newest textbook on QM, that the interpretation problem is unsolved. Landau&Lifshitz and Dirac are very close to my view. I've never understood Bohr, who used to write very enigmatic papers. Einstein's view is, in my opinion, ruled out by the outcome of Bell experiments. I don't know the other books mentioned well enough to say anything concerning their view on interpretation.
Think about it. A macroscopic system tends to "prepare itself" in a state of (local) thermal equilibrium (let's not consider systems with long-ranged forces for the moment) but that takes time. So I still don't know, what you mean by "spontaneously".
That's a very interesting statement. I'm not sure I understand your view on things so is it possible to clarify what you mean here?
Are you suggesting that the 'textbook' axioms are incorrect (I think you called them 'ridiculous' in another post)?
Or are you suggesting that superposition (in a quantum sense) is not a physical phenomenon?
I agree that it may be extremely practically difficult to devise an experiment that is capable of testing an 'idealized' quantum system - so I can see why it might be possible to say that the idealized axioms don't apply FAPP - but is it your view that the idealized axioms are actually wrong?
Or is your view that the states and wavefunctions and mathematical machinery of QM is nothing more than a collection of mathematical devices, divorced from 'reality', that allows us to calculate probabilities in experiments? So the maths gets us the right answers but tells us absolutely nothing about what might be 'going on'?
Is it so hard to press the Quote button? :cool:
I usually only quote a message, if my answer is not directly after the message I refer to. That's not working with this thread, because the frequency of answers is too high. zonde was quicker with his posting than I could write mine. For clarity I copied the quote into my message. Sorry for the confusion.
What exactly is definitely not true? I really think that Ballentine thinks that most of the others have not understood QM properly.
It's definitely not true that I think that all the "founding fathers" of QT are wrong or haven't understood their own theory. Ballentine, in my opinion, also follows just standard QT. He's even emphasizing the bare physics content of it, and there's no contradiction of "minimal interpretation" to the Copenhagen flavor without collapse. As I said, I never understood Bohr completely, but as far as I can see he had a pretty similar view, taking the quantum states as epistemic.
They are appropriate for an introductory course where emphasis is on simple, paradigmatic systems. But already a simple position measurement is not covered, since it cannot collapse to an eigenstate - position has no normalizable eigenstates. Realistic measurement is a highly complex subject, not something appropriate for foundations.
But why then Ballentine made a wrong prediction about the quantum Zeno effect? Is it just a little mistake that can happen to everyone? Or is it a deep disagreement with the others?
Can you clarify what you mean by "without collapse"? Is it just a matter of words, calling it update instead of collapse, as from the earlier discussion with atyy? Or is there a difference in the approach to calculations? How do you do without update in all experimental scenarios?
The point is that a measuring device does not have yet another measuring device measuring it. So the idea that the state of a system is only meaningful in predicting probabilities for what a measuring device would measure is not true for macroscopic systems.
vanhees71 said:
Common practice today disproves you. It has become more and more possible in the recent decades to handle single particles and photons and prepare them in many kinds of pure and mixed states, everything in accordance with standard QT.
I don't understand how your remarks address what I said. For a microscopic system, the "state" is meaningful in two ways: (1) the preparation procedure needed to put the system in that state, and (2) the probabilities that state gives for future measurements. But for a macroscopic system, there is a notion of state that doesn't have either of those features. A macroscopic system simply is in some definite state or another.
There is anyway no difference in calculations when it comes to the physical content of quantum theory. The minimal interpretation is just saying that the state has probabilistic information about the outcome of future measurements and nothing else.
