Must we always use absolute value for lens magnification?
The discussion clarifies that magnification in optics is a signed quantity defined by the formula m = -(i/o), where i is the image distance and o is the object distance. A negative magnification indicates an inverted and real image, while a positive magnification indicates an erect and virtual image. The necessity of using absolute values depends on the context of the problem; if the question specifies the factor of size reduction, the negative sign is not required. For accurate results, especially in multi-lens systems, maintaining the sign convention is crucial.
  • Understanding of basic optics principles
  • Familiarity with the lens formula and image formation
  • Knowledge of real vs. virtual images
  • Ability to interpret signed quantities in physics
  • Study the lens formula and its applications in optics
  • Learn about real and virtual images in detail
  • Explore the effects of multiple lenses on image formation
  • Investigate common problems involving magnification and image height
Students studying optics, physics educators, and anyone interested in understanding image formation through lenses and the implications of magnification signs.
Jonforall
My brother's physics teacher says that magnification and height of image are always positive. Is she right?
It depends on the context. It does not make sense to have a negative magnification if you look at it strictly as a factor by which an image is reduced or enlarged. However the usual definition of the magnification is a signed quantity ##m = -(i/o)## where ##i## and ##o## are, respectively, the distance of the image and object from the lens. The convention is that if the magnification thus defined is a negative number (both ##i## and ##o## are positive), the image is inverted and real; if the magnification is a positive number (##i## is negative), the image is erect and virtual. This convention helps sort out whether images are real or virtual and inverted or erect and comes in handy when one considers the formation of images by multiple lenses. The height of an image is the magnification multiplied by the height of the object. Thus, the height of the object carries the sign of the magnification.
So should we always use absolute value in answering every problem that tells us to find height of image and its magnification?
Let me repeat: There is no "always" because it depends on the context. If the question gives you the focal length and the position of the object and asks for the magnification, I would include the negative sign. If instead the question asks "by what factor is the image smaller than the object?", I would not include the negative sign. The height of the image is usually positive although sometimes people who write a question asking for a height expect a negative sign to indicate that the image is inverted. This becomes important when you want to find the image formed by two of lenses in which the image formed by the first lens becomes the object for the second lens. Dropping the sign will get you in trouble. The upshot of all this is that only your instructor knows for sure what answer is expected, so ask.
Thanks
