Mutual Inductance between two conductors
Jason-Li
The mutual inductance between two circuits as shown is 0.2 μH.
It may be assumed that (R1 + RL1) >> ωL1 and that (R2 + RL2) >>ωL2.
(a) Estimate the crosstalk voltage at the load of circuit B when the signal
source of circuit A is V1 = 1 V at 1 GHz.
(b) Plot the crosstalk voltage (at the load of circuit B) as a function of
frequency.
(R1 + RL1) >> ωL1 and (R2 + RL2) >>ωL2.
Circuit schematic of two coupled inductors: L1 with series R1 (50 Ω) and 1 V rms source, loaded by RL1 (50 Ω); L2 with series R2 (1 kΩ) source, loaded by RL2 (3.3 kΩ); dots mark terminals A and B, with 0.2 µH mutual inductance shown between them.
Hello hope everyone at PF are keeping well!
Looking at this problem but don't know if I have oversimplified it and my final answer doesn't seem right?
So I drew the equivalent circuit:
Hand-drawn circuit schematic of two coupled inductors: top loop has source V1 (1V RMS), R1 = 50 ohm, an inductor, a diode, and RL1 = 50 ohm; bottom loop has V2, R2 = 16 ohm, an inductor, and RL2 = 3.3 kohm; mutual inductance M = 0.2 uH between them.
Hand-drawn equivalent circuit: a voltage source labelled jωMI_1 in series with a loop connecting resistor R_L1 on the left and resistor R_L2 on the right, with the bottom wires grounded.
Then went onto calculate:
I1 = 1/(R1+RL1) = 0.01A
ω = 2πf = 2π*109 rads-1
so then with Vi being the inducted voltage:
Vi = jω * M * I1 = 2π*109 * 0.2*10-6*0.01 = 12.566V This seems a bit high?
I also did the classic ohms law and did VL2 = Vi / (R2+RL2) * R2 = 9.643V to get the answer for (a)? I am really unsure if I have approached this correctly, any help would be greatly appreciated.
Then for part (b) I was just going to plot a straight line as the function is
Vi= jω*M*I1 I would change this to
Vi = (2π*M*I1)*f which is the same as y=mx ?
  • Circuit schematic of two coupled inductors: coil L1 with series resistor RL1 (50 Ω) and source R1 (50 Ω) with 1 V rms source V1 on the left, coil L2 with RL2 (3.3 kΩ) and R2 (1 kΩ) on the right, mutual inductance 0.2 µH dashed between A and B.
I think the primary current is flowing through M, which has a large reactance. So I1 = V1/omega M (approx).
I think as it's mutual inductance current I1 won't be altered by M, but will effect M?
I have calculated I1 and then from that I can calculate the mutual inducted voltage?
